Hood Damper: Pros & Cons?
Old Dec 26, 2005 | 04:18 PM
sluggoZ's Avatar
sluggoZ
Default Hood Damper: Pros & Cons?
I want to order the Tein Hood Damper...are they good...bad...?? Easy to install? No need to have it? A must??
I need advice bros! Thanks!
Old Dec 26, 2005 | 04:49 PM
Queens 350z's Avatar
Queens 350z
From what i have read and seen you have to cut the battery and/or fluid covers for the hood to close right. They look nice but i dont want to do all that work.
Old Dec 26, 2005 | 05:01 PM
zzaa604's Avatar
zzaa604
you could always get a shop to do it.
Old Dec 26, 2005 | 05:07 PM
TruBluZ's Avatar
TruBluZ
You don't have to cut the covers. You cut the other plastic pieces that the covers attach to. Or, you just remove all the plastic!
Old Dec 26, 2005 | 05:10 PM
Queens 350z
Yes you are right. Sorry that what i meant to say. But i like the way the covers look and the plastic around them.
Old Dec 26, 2005 | 05:14 PM
TruBluZ's Avatar
TruBluZ
Me too. I had other hood shocks before and had to cut the pieces. Now, I ordered the stock plastic so I can put it back to normal since I got rid of the shocks. 1 step forward, 2 back
Old Dec 26, 2005 | 05:28 PM
Tony@Performance's Avatar
Tony@Performance
Vendor - Former Vendor
Having hood shocks is cool, something nissan and infiniti should have done I think from the get go on the Z and G. I never got around to it, because I just don't feel like cutting my covers. I'm too lazy for it, but it's not hard to do at all. Also, if you have a CF hood, it's not really recomended, because some hoods may be too weak at the mounting point or too light, and the shock may put too much pressure on the skeleton portion of the hood, creating cracking issues. I am contemplating on the hood shocks for my car, since my stillen hood is actually reletively heavy, around stock weight.
Old Dec 26, 2005 | 05:43 PM
PumpedVA's Avatar
PumpedVA
I have them even have them color matched to the car but I sure wish I could run a cf hood
Old Mar 29, 2006 | 12:29 PM
HarvesterUT's Avatar
HarvesterUT
if you guys wait a week or two, i am currently developing a hood spring system that might not have any modifications to the plastic covers....or even the car itself. i am waiting on the springs and mounting brackets to arrive.
Old Mar 29, 2006 | 03:08 PM
Alberto's Avatar
Alberto
Cranky FI Owner
^^Cool, keep us updated...
Old Mar 29, 2006 | 03:17 PM
GTNPU Z's Avatar
GTNPU Z
VERTEX Army CEO
Sweet! Keep us posted! I was looking into the shocks but never liked the fact you had to modify the plastic panels.
Old Mar 29, 2006 | 03:37 PM
NA350Z's Avatar
NA350Z
Nissan should have put them on these cars standard. My 1990 Supra Turbo had them, they're very convenient. I mean I have a touring model and for a 32K + sports car something like hood dampers should be standard.
Old Mar 29, 2006 | 04:17 PM
vitaminZ's Avatar
vitaminZ
i have these
i purchased them from 350ZTN a while back. he did the R&D and it shows. i paid like $85 shipped (i think). not sure if he is still selling these but i would give him a PM and see. they have worked out great for me!
Old Mar 29, 2006 | 04:57 PM
G352NV's Avatar
G352NV
I have the TEIN's and modded them so you dont have to cut anything. Yes its on a G BUT it would be the same on a Z. Drill a hole in the fender jamb.I did a DIY on these but Im having trouble finding it.
Attached Thumbnails Hood Damper: Pros & Cons?-picture-1909.jpg
Old Mar 29, 2006 | 04:58 PM
G352NV's Avatar
G352NV
BTW Ive had my hood up and down more then any car should have they have help up just fine with NO prolems.
Old Mar 29, 2006 | 08:24 PM
HarvesterUT
i think the Z's have less clearnace under the hood than the Gs. it's a tight fit. well my current plans are to have NO drilling or modification to any part of the car. i wont know for sure until all my parts arrive sometime later this week. here's hoping i took good measurements!
Old Mar 29, 2006 | 09:02 PM
G352NV's Avatar
G352NV
Ive seen it done on a Z.
Old Mar 30, 2006 | 04:17 AM
buzzardmountain's Avatar
buzzardmountain
Subscribing.
Old Mar 31, 2006 | 10:29 AM
z350boy's Avatar
z350boy
I ordered a set of Tein's dampers and think I have away to minimize damage to the rubber piece:
(1) Remove the rubber piece and have the dampers installed
(2) Take a piece of thin cardboard and lay the rubber piece on top.
(3)Trace out a pattern
(4) Lay the cardboard pattern in the enginge bay and make a single straight line cut in the cardboard which allows the pattern to fit around the damper
(5) Once the pattern is in place mark the area where the damper meets the pattern ( make it just large enough to fit around the damper)- be conservative
(6) Once that is done cut out the marked area and place the pattern down again with the cuts, cut just a little at a time until the fit is snug, it may take a few tries to get it snug
(7) Once you are satisfied lay the pattern over your original rubber piece and make your cut. If done correctly one cut should be needed.
What do you think?? Sound like a plan??
Old Mar 31, 2006 | 11:41 AM
HarvesterUT
there was one guy on here that basically did that. It worked, but you still have to cut up your plastic. I am trying to make a set where you don't have to do that. If my plan doesnt work, then I think its almost impossible without making your own crazy brackets and/or getting some super skinny gas springs
