Problem w/ hatch since nismo spoiler install
Old Jan 2, 2006 | 08:41 AM
Moreorles's Avatar
Moreorles
Default Problem w/ hatch since nismo spoiler install
I got a JDM Nismo spoiler for Christmas from my wife. I was totally surprised. She ordered it form Performance Nissan. Anyway,it has since been painted and installed. Since the install, my Hatch won't pop open like it used to. I have to "pop" it with the remote 2 or 3 times before it releases. It seems to be the weight of the spoiler. A couple of other guys have looked at it and agree. Is there anyway to adjust the tension on the release? Does anyone else experience this problem? Thanks for the help.
Old Jan 2, 2006 | 08:43 AM
Vamos_Rafael's Avatar
Vamos_Rafael
LOL...
i have to same problem but with a much bigger spoiler...
it is the weight
Old Jan 2, 2006 | 08:57 AM
SpeedRcr's Avatar
SpeedRcr
didnt they have stronger struts for that as a fix?
Old Jan 2, 2006 | 08:58 AM
ZThang's Avatar
ZThang
Beneath the lid of the hatch there is a weighted plate. Remove it after you install the spoiler and it'll help a little.
Old Jan 2, 2006 | 09:16 AM
davidf's Avatar
davidf
Join the club.
Old Jan 2, 2006 | 09:55 AM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
Did you remove the rear hatch weight?
it is under the plastic finisher... It weights about 12lbs...
If that doesnt work you need the stronger rear hatch shocks...
http://performancenissanparts.com/ca...oducts_id=1429
Old Jan 2, 2006 | 09:57 AM
Vamos_Rafael
200+dollars?
damn... I am carrying an empty shoe shipping box to hold the hatch while im doing stuff ...
i cant justify that cost
Old Jan 2, 2006 | 10:31 AM
Escobar's Avatar
Escobar
So if you pop the hatch and take off the plastic covering there will be a plastic finisher in there that unbolts or something? 12 lbs is kinda heavy, what is the reason for it? I have been experiencing the same problems with the cold weather and having to pop the hatch multiple times to open it.
Old Jan 2, 2006 | 10:42 AM
Z_Driver's Avatar
Z_Driver
Master
Anyone have a picture of that plate. I opened mine up and I didn't see it. So, if someone has a picture I can make sure. If there is 12lbs in there I want to get rid of it.
I took off the wiper and motor. When I did that I looked for the plate and didn't see it.
Old Jan 2, 2006 | 10:57 AM
Jason@Performance
Performance Nissan
it may have been removed... but its held in by 4 bolts...
Old Jan 2, 2006 | 11:42 AM
Escobar's Avatar
Escobar
oh ok. so its just below the glass after removing the body panel
Old Jan 2, 2006 | 12:42 PM
CC 350Z's Avatar
CC 350Z
Exactly.. Should take 5 minutes to complete.
Old Jan 2, 2006 | 02:07 PM
Fletch69z's Avatar
Fletch69z
I have the same problem and I don't have an aftermarket spoiler, . I'm taking my weight out soon, but I thought it only weighed 4 or 5 pounds?
Old Jan 2, 2006 | 02:09 PM
Escobar's Avatar
Escobar
I just went and looked, there is no screws or anything on the panel. Is it just those fast clips or something? How do you get the panel off without messing it up?
Old Jan 2, 2006 | 02:39 PM
DJMC126's Avatar
DJMC126
I just had the dealer do mine, I said if it doesn't pop....IM GOING TO DO SOME POPPING!!! The guy laughed and made it work! hahaha
Old Jan 2, 2006 | 02:44 PM
350z bra's Avatar
350z bra
ya my stillen wing is heavy also
Old Jan 2, 2006 | 02:45 PM
MustGoFastR's Avatar
MustGoFastR
That weight is 4lbs at best...
Old Jan 2, 2006 | 02:55 PM
Escobar's Avatar
Escobar
yeah, 12lbs sounds heavy.
Old Jan 3, 2006 | 02:24 AM
Z_Driver's Avatar
Z_Driver
Master
Just checked for mine. The only thing there is four presserts for mounting it.
I guess someone took it out when I bought my car and ordered my OEM spoiler in preperation for the install. I wish they would have given me the part. However, I don't see that I will ever have a use for it.
Thanks for the information..... No wonder I couldn't locate it before. That's because it wasn't there.
I have a G35 wing on there with the factory deck shocks and it keeps the hatchback up nicely.
Old Jan 3, 2006 | 02:31 AM
Z BOY's Avatar
Z BOY
https://my350z.com/forum/exterior-and-interior/101463-weight-stock-z-rear-hatch-counterwt.html
can also try the $.03 solution in the hatch springs, but even after removing the wt and adding the 3 pennies, i still have to use my other hand to open the hatch in cold weather, ever since i installed my g wing.
