newb HID question
Old Jan 11, 2006 | 11:33 AM
umzzz's Avatar
umzzz
Cwest Army
Default newb HID question
i noticed on the stock d2r bulb that there is a black shading on the inside of the tube. when the bulbs are reinstalled into the car is that sheilding suppose to face a certain direction (ie should the sheilding be to the outside of the car with the clear part towards the middle of the car etc). does it make a difference which way they go or can you just put them in any direction
found this diagram which may help point out what i am talking about:
http://lib.store.yahoo.net/lib/rodi/...ad2install.pdf
Old Jan 11, 2006 | 05:57 PM
umzzz's Avatar
umzzz
Cwest Army
bump...anyone?
Old Jan 11, 2006 | 06:07 PM
need Z's Avatar
need Z
any direction should be fine. I work with Xenon bulbs all day and can't imagine why it would make a difference.
If it's dark or smoked due to use though, then it's a good idea to rotate it so it's not on the top, but other than that you'll be fine.
Old Jan 12, 2006 | 08:06 AM
Jun's Avatar
Jun
the mark should be on top, the ceramic tube should be on the bottom.
If you install them wrong, you won't see anything.
Old Jan 13, 2006 | 06:52 AM
umzzz's Avatar
umzzz
Cwest Army
hmm looks like mine may be upside down i looked through the housing and i can see the shaded part but its towards the bottom. gonna take a look this weekend and see if i can fix it. hopefully ill be able to get them mounted properly.
Pleask
Dec 21, 2021 03:17 PM
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
