350z nismo wing problem plz help!
hey guys, i put the nismo wing on my car and now my trunk wont stay open
anyone have this problem? are there better trunk shocks i need to get? thanks for ur help
Recomended by Nissan when installing the Nismo Rear Deck Spoiler are the upgraded shocks ($340.00 including install at dealer). A BIG WASTE OF MONEY. Problem solved for 2 weeks or so, and then back. I removed the weight from the hatch and problem solved for 6 months so far.
Can someone please post on the proper way to remove the plastic cover to access the weight assembly? I tried to access the weight yesterday, it was cold and I didn't want to crack or force the cover.
You have to force it. There are 8 clips that you will need to pop. It is not hard once you get the first two. Here are directions from Courtesy Nissan. This is for mounting an OEM spoiler so ignore the rest but it does show how to remove the cover.
Good luck
http://www.courtesyparts.com/instruc...RRSPL_pg2.html
hardkicks
Sep 20, 2015 12:28 PM
