For those who have upgraded lights with HID Coversion Kits
Old Feb 5, 2006 | 02:19 PM
Peking's Avatar
Peking
Default For those who have upgraded lights with HID Coversion Kits
This is a picture taken from my GP Thunder Conversion Kit Manual... It is the H7 Model... 9,500K (Sky Blue) kit.
As you see in the manual it shows 4 Connector Types for application I guess of bulb type. Which I did not recieve in my kit, I guess cause I ordered the H7 and there does not seem to be a connector type for that.
So does that mean for those two prongs there is a connector already on the car for that or am I missing something for that connection of the red wire (positive), and black wire (negative)? Or is a connection for those not needed with the H7?
Any help would make me very grateful before I start this conversion.
Thanks,
Jon
Old Feb 5, 2006 | 02:26 PM
jor8888's Avatar
jor8888
suppose be plug & play that easy so u must be missing adapters.
Old Feb 5, 2006 | 04:27 PM
Driven1's Avatar
Driven1
Professional
Looks to be very similar to the Pilot conversion kit. If it is indeed the same or similar the red goes to positive/switch positive and the black to ground. Sometimes depending on the circumstance and application these need to be switched, but that mainly for domestic conversions. Hope that helps.
Old Feb 6, 2006 | 05:28 PM
Peking's Avatar
Peking
Well not so sure since there isn't anything about a H7 in the manual about it, and I sent a email to the place I bought it from... So waiting to hear back from them I guess, along with sending a PM to Vee Tec who also has this kit to see if he remembers it.
That somewhat does because it goes along with something I was reading elsewhere, though the black goes to ground which wouldn't be to hard... But the positive wire, where to connect?
Anyway thanks guys for responses.
Old Feb 7, 2006 | 10:36 AM
Jun's Avatar
Jun
you will have an H7 connector in the housing after you take out the H7 bulb.
plug the red cable into the side of the connector that has the red wire, and the black cable into the side of the connector with the black wire. Once you open it, you will see what i'm talking about.
Hope that helps.
Old Feb 8, 2006 | 01:46 PM
showstoppertk's Avatar
showstoppertk
Hope that helps.
+1. after you unplug the stock h7 bulb you stick those prongs into the socket that the h7 bulb was in.
Old Feb 20, 2006 | 03:25 PM
Peking's Avatar
Peking
Hope that helps.
Oh man thanks guys, I feel better now about it
Going to do it hopefully soon.
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
samansharif
Sep 25, 2015 12:31 PM
