60mm gauge POD!!?!?
Old Feb 6, 2006 | 08:44 PM
veilside350zTT's Avatar
veilside350zTT
Default 60mm gauge POD!!?!?
Ok guys im going with the defi BF series gauges. But they come in 60mm. the problem is that i cant find any damn triple gauge pods for the pillar in 60mm they are all for 52mm..
Any Ideas?
Old Feb 6, 2006 | 08:49 PM
Bubble's Avatar
Bubble
-REPLICA ARMY-
something weird. Why 3 threads with the same topic?
Old Feb 6, 2006 | 08:52 PM
pope's Avatar
pope
go to a stereo shop and have them custom make a fiberglass gauge pod. they could make it to fit however/wherever you want.
Old Feb 6, 2006 | 09:35 PM
veilside350zTT
Pope thanks for the obvious.. I wud rather not spend several 100 dollars on a custom guage pod.. Im lookin for a replacement peice like wat the have in 52mm
Old Feb 6, 2006 | 10:03 PM
Volk350Z's Avatar
Volk350Z
Master
I had a 52mm gauge pod on my S14 with the HKS 60mm, I just us a dremel and open up the hole..
Old Feb 7, 2006 | 10:34 AM
Jun's Avatar
Jun
remove the 3 gauges in the center console
Old Feb 7, 2006 | 10:43 AM
pope's Avatar
pope
if you are paying several hundred for something like that you are a sucker...
Old Feb 7, 2006 | 10:55 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
nicely done.....
https://my350z.com/forum/forced-induction/170074-60mm-pillar-gauge-pod.html
https://my350z.com/forum/exterior-and-interior/170073-60mm-gauge-pod.html
https://my350z.com/forum/exterior-and-interior/170072-60mm-gauge-pod.html
https://my350z.com/forum/showthread.php?t=170071
...id tell ya to search but thats all youd find, sry i couldnt help
Old Feb 7, 2006 | 11:46 AM
nexstage350's Avatar
nexstage350
i had mine custom
might have to do the same
Old Feb 7, 2006 | 08:40 PM
veilside350zTT
Custom fiberglass is expensive.. Maybe not several 100 but it wouldnt be cheap.. Custom fiber glass than paint.. Will easily be close to 200bucks
Old Apr 23, 2009 | 01:50 PM
xzotklr's Avatar
xzotklr
^^ Just use a Dremel with a sandpaper bit. You will actually be elongating the hole. The lip needs to be sanded down. Go from the inside using vertical motions around the inner ring until the lip is gone; then elongate the hole. I got my gauges to fit flush....Good luck.
Old Apr 23, 2009 | 01:56 PM
davidc81's Avatar
davidc81
i have 60mm greddy gauges installed in the stock center location.
Old Apr 23, 2009 | 02:56 PM
stormcrow's Avatar
stormcrow
three years old and you respond? nice shot, Quick Draw.
Old Apr 23, 2009 | 03:58 PM
Done Deal DR's Avatar
Done Deal DR
Old Apr 23, 2009 | 08:56 PM
ECLIPSEGST25's Avatar
ECLIPSEGST25
only use a Autometer 3 gauge pod. I have Apexi 60mm and used a dremel and they fit great. Dremel small amounts at a time to you don't make the holes too big.
bcoffee20
Nov 19, 2015 06:39 PM
abarclay
Wheels Tires
Sep 21, 2015 04:51 AM
Calinismo350z
Sep 14, 2015 04:04 PM
