how do i install rear splash guards?
Old Feb 15, 2006 | 02:30 PM
indierock's Avatar
indierock
Default how do i install rear splash guards?
I bought front and rear guards. i installed the fronts but i can't get the rears installed b/c the wheel is in the way. Please don't tell me i have to remove the rear wheels to install them.
Old Feb 15, 2006 | 04:05 PM
Netko350Z's Avatar
Netko350Z
Yes
Old Feb 15, 2006 | 06:15 PM
indierock's Avatar
indierock
Originally Posted by Netko350Z
Yes
is there such a thing as a 90 degree drill bit? that curves like an upside L?
Old Feb 15, 2006 | 06:24 PM
mutock's Avatar
mutock
How about using a 90 degree ratchet screwdriver? You can get them at Home Depot.
http://www2.shopping.com/xPC-General...crewdriver_Set
Old Feb 15, 2006 | 06:36 PM
indierock's Avatar
indierock
the thing is that i need to drill a 5mm hole which i think is a 3/16 inch drill bit before i can screw in anything. any other ideas? also thanks for trying to help out.
Old Feb 15, 2006 | 06:42 PM
ahwai519's Avatar
ahwai519
just line up the bracket provided... use a screwdriver to screw a small sharp bolt in slowly. Once you screwed a hole enough to hold the bolt, remove the bolt and line up the rearguard and screw in the bolt that comes with the package...thats the way i did mine.
Old Feb 15, 2006 | 07:03 PM
DavesZ#3's Avatar
DavesZ#3
Actually, there are right-angle drill heads/adaptors.
In the 4 hours since you first posted the question, you could have easily jacked up your car, removed a wheel, drilled the hole with a regular drill. Repeated on the other side.
Old Feb 15, 2006 | 07:31 PM
indierock's Avatar
indierock
i don't have a jack or else i would have done that. lol.
Old Feb 15, 2006 | 07:47 PM
rockinbboy's Avatar
rockinbboy
Didn't your car come with one?!
Old Feb 16, 2006 | 03:56 AM
DavesZ#3's Avatar
DavesZ#3
Yeah, what are you going to do if you get a flat and have to put on the spare?
Old Feb 16, 2006 | 04:33 AM
k3silk's Avatar
k3silk
your jack should be under your carpet not being an *** you just may not know that?
Old Feb 16, 2006 | 11:42 AM
indierock's Avatar
indierock
oh ya good point. lol. damn i'm an idiot. i'll have to check it out this weekend when i get a chance. where should i place the jack at exactly?
Old Feb 17, 2006 | 11:10 AM
cbrflyer919's Avatar
cbrflyer919
OMG, dont touch your car please. Just pay someone to do this for you...PLEASE
Old Feb 17, 2006 | 05:38 PM
indierock's Avatar
indierock
lol...hey i just want to make sure. but thanks for the advice.
Old Feb 17, 2006 | 06:29 PM
DavesZ#3's Avatar
DavesZ#3
Look in section 6 of the Owners Manual titled "In Case of Emergency". It shows you where the jack is stored and the location of the lift points on the body of the Z.
hulkout
Apr 28, 2017 09:00 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
samansharif
Sep 25, 2015 12:31 PM
