Just bought these!! NEED HELP
Old Mar 3, 2006 | 09:42 AM
Torched Z's Avatar
Torched Z
Default Just bought these!! NEED HELP
http://cgi.ebay.com/ebaymotors/ws/eB..._BIN_Stores_IT
i just bought these and got them in today i tried searching to figure out how to wire them to the turn signal but the search isnt working for me! Can someone please help me out!!
thanks in advance,
Nikita
Old Mar 3, 2006 | 10:25 AM
MustGoFastR's Avatar
MustGoFastR
All you need is those little blue clip on wire connectors and tap the wires into the factory signal (or parking light, whichever way you want it) wires. Very easy.
Old Mar 3, 2006 | 10:44 AM
Torched Z's Avatar
Torched Z
so does that mean that i have to get the head lights out to tap into them??? if so how do i do that???
im sorry if its easy and im not understanding im new with this whole car first time ever working on it!!
thanks again!!
Old Mar 3, 2006 | 12:14 PM
cbrflyer919's Avatar
cbrflyer919
This is about one of the easiest things you could ever do to the car. Not trying to be a jerk, but I SERIOUSLY dont think you need to be touching your car. Just pay someone, and get it done right...
Old Mar 3, 2006 | 12:18 PM
cbrflyer919
On a side note..You have quite an extensive mod list....Do you really have all this stuff?? If so, just take it to ANY of the shops you had that stuff installed at. And BTW, you do need to get to the back of the headlights...you could tap into the wiring on the output side of the flasher module, but itt is easier to get to the back of the headlight considering you have to take the front bumper off to actually install the lights themselves
Old Mar 3, 2006 | 12:24 PM
Torched Z's Avatar
Torched Z
i got the car that way and like i said before this is the first time i have worked on this car. I had a Pontiac GTP and did all my mods myself!! Exterior and Engine mods too!!
Just asking for help is all!! i actually found a way to get the headlights off and saw that i have to get the front bumper off!! so i will be attempting that tonight.
Old Mar 3, 2006 | 12:32 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
You do not have to take the front bumper off!
You will need to jack the car up and remove each front tire in turn and pull the plastic wheel well liner apart. That's going to give you access to both the physical mounting and electrical wiring. On the starboard side (passenger's) you can loosen the bumper cover to allow you to get in behind the water resevor mounted there - pop the plastic retainers out with the hood open and remove three additional screws that hold the front of the bumper on just inside the forward part of the wheel well.
I've done a write up with pictures but have that link at home. PM me if you want it.
Old Mar 3, 2006 | 12:37 PM
cbrflyer919
Pictures are gone because it is an old thread, but still this should help...If theres anything I can add, It would be that the tabs on the top of the bumper need to be pulled up only slightly so that the whole tab can then slide out of the hole...if you pull up all the way, the tab spreads itself inside the hole and you will end up breaking them...Also, make sure to put a sheet or towel down under the bumper on the ground as it more than likely will fall off once youve pulled that last bolt out, this prevenst scratching...also the fender liners dont need to be removed, just pull the edges out from the fender lip with a flathead wrapped in electrical tape to prevent scratching and get your screwdriver in there (note, you will need to turn the wheel all the way to the left to do the right fender and all the way to the right to do the left fender)...thread link below...good luck
https://my350z.com/forum/showthread....bumper+removal
Old Mar 3, 2006 | 03:34 PM
Jun's Avatar
Jun
damn, you paid $109 for those things?
Old Mar 3, 2006 | 10:17 PM
Torched Z's Avatar
Torched Z
everything ended up working out the passenger side one was a paon in the *** but it looks nice!!
thanks
Uriyo_
Sep 8, 2021 08:46 AM
Rev_Night
Nov 7, 2020 06:00 PM
Fixxxercask
Nov 9, 2015 11:10 AM
