Passenger Window Switch Removal
Old Mar 13, 2006 | 04:18 PM
hji1945's Avatar
hji1945
Default Passenger Window Switch Removal
Can somebody tell me how to take that thing off? Do you just pull em off? Or do you have to take the handle out first? Any screws I have to take out? Thanks
Old Mar 13, 2006 | 06:40 PM
hji1945's Avatar
hji1945
Anybody?
Old Mar 13, 2006 | 07:04 PM
MJBsZ's Avatar
MJBsZ
This may help. it looks like you just unscrew the door pull and it should come out. Just look for that metal retaining clip on the one side
Old Mar 13, 2006 | 08:46 PM
hji1945's Avatar
hji1945
Thanks. Where do you find those stuff?
Old Mar 14, 2006 | 03:29 AM
JDMFairlady21's Avatar
JDMFairlady21
nissan TSB
Old Mar 14, 2006 | 05:54 AM
Santacruzslick's Avatar
Santacruzslick
Veteran
Take the metal trim piece off of the handle(flat head screw driver from the top should pry it off easily), there are 2 10mm bolts down in there that need to be removed. You'll need an extention to get in there. You should be able to slightly pull the handle assembly out now. Now you can lift up on the little pad from the back and it should pop off. Next step is to pull up on the switch piece and viola!
Old Mar 14, 2006 | 07:59 AM
hji1945's Avatar
hji1945
Thanks guys..I wasn't sure if I had to take the handle off first. And if I had to, I didn't know how to..Lol..Thanks anyway..
Rev_Night
Nov 7, 2020 06:00 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Depravity
Oct 1, 2015 04:49 PM
samansharif
Sep 25, 2015 12:31 PM
