Changing Hoods, please advise steps
looks pretty simple but can someone just review the steps so i make sure i do this correctly. Im changing to a CF OEM style hood...
Originally Posted by Rickdogg
Remove bolts and put bolts back. You may have to adjust the hood latch a bit. Also, make sure another person is helping you or even better 2 other people
1. open driver side door
2. pull lever for hood release
3. pull latch under hood and raise
4. friend either side holding hood
5. unbolt all bolts
6. order friends to remove hood
7. order friends to fetch new hood
8. order friends to align new hood
9. insert bolts and tighten
10. test hood for alignment
11. adjust if necessary
12. close hood
13. take pic and post it
14. have a corona
(sorry, is this a bit overkill?)
5. unbolt all bolts
12. close hood
14. have a corona
5. unbolt all bolts
12. close hood
14. have a corona
5. unbolt all bolts
12. close hood
14. have a corona
5. unbolt all bolts
12. close hood
14. have a corona<<<<<<<<<<< DELETE !!!!---Insert BudweiserOther wise all very good advise
5. unbolt all bolts
12. close hood
