installing TCS button???
Old Apr 3, 2006 | 09:13 PM
GMZ's Avatar
GMZ
More like oranges to grapefruits, they are both stability control systems. VDC you can disable with a push of a button btw.
Old Apr 3, 2006 | 09:31 PM
roast's Avatar
roast
^ No you can't. Not completely.
Old Apr 4, 2006 | 02:48 AM
Kolia's Avatar
Kolia
Not again...
Old Apr 4, 2006 | 08:28 AM
maxpowers's Avatar
maxpowers
Originally Posted by davidv
Forum members with VDC/TCS are trying to disable it. Those who drive a Base want to add TCS. Who can figure?
Life is so dam complicated!
Old Apr 4, 2006 | 04:09 PM
roast's Avatar
roast
Originally Posted by Kolia
Not again...
Just stating the obvious, since apparently it was necessary.
Old Apr 4, 2006 | 06:46 PM
MyZ4U2C's Avatar
MyZ4U2C
You cant disengage the VDC completely with the button? I beg to differ. I can turn mine off and and i can do donuts all day long and fishtail changing gears and drift around corners and nothing kicks in.
Old Mar 18, 2012 | 02:54 PM
e30cabrio's Avatar
e30cabrio
I bought a base because I did not want TCS.
I found this thread because I want to use a TCS switch to manually control my fans.
The switch has four pins and I can't find the diagram for the pinout. I don't have the switch yet and if it comes to it I'll trial and error it but was hoping to know before I get it. FWIW, I spent 45 minutes wading through the service manual just finding TCS is under BRC.
Old Mar 18, 2012 | 03:51 PM
DavesZ#3's Avatar
DavesZ#3
diagram in the BRC section.
Old Mar 18, 2012 | 04:07 PM
e30cabrio's Avatar
e30cabrio
There are over a dozen pages of diagrams. I just spent the 10 minutes since you posted that and did not find it. Thanks.
Old Mar 18, 2012 | 04:20 PM
DavesZ#3's Avatar
DavesZ#3
It's from the diagram BRC-TCS-02. The second of the TCS section diagrams right after the TCS schematic that shows the overall wiring.
Old Mar 18, 2012 | 04:23 PM
e30cabrio's Avatar
e30cabrio
Thanks. Apparently I had closed BRC and was looking in PG. GAAAAAAAAAAAA :P
Old Mar 18, 2012 | 05:04 PM
bbs350z's Avatar
bbs350z
you can add in an aftermarket traction control unit
Old Mar 18, 2012 | 05:11 PM
e30cabrio's Avatar
e30cabrio
I bet if I added whatever modules are missing with my flash that gave me cruise I could have TCS & VDC but I bought the base to not have them or leather or whatever else I was missing before I added the quaife, homelink and cruise so I now have exactly what I wanted.
I just want to use the oem switch for my fans.
Just looked, wire harness is there so all I have to do is splice power and ground for the fans and I get an illuminated switch for my fans.
loudtoyz
Apr 6, 2023 04:52 AM
