Rolled Fenders
Old Apr 6, 2006 | 06:16 AM
kcobean's Avatar
kcobean
Originally Posted by swizzle'z350
What about eibach springs with 20" wheels? Is that going to rub? I rolled tha fenders on my last carand dont recommend doing it!
It depends on what the offset of the wheel is.
Also, I think most 20" wheels on Zs are running a 30 profile tire, which will make your rolling circumference (and radius to the tire edge) larger than an OEM 18" Rays wheel, whereas a 19" wheel with a 245/75 front and 275/35 rear are actually a slightly smaller radius than a the OEM track-model wheel (i.e. the lower profile tire actually more than makes up for the 1/2 inch increase in wheel radius.)
I don't want to give any bogus advice on what would work and what wouldn't. I'd call one of the wheel/tire sponsors of the board and let them answer that question.
Old Apr 6, 2006 | 08:33 AM
taurran's Avatar
taurran
Originally Posted by z350boy
If that's the look you want lowering the car get coilovers and use toe bolts in the rear and aftermarket A-arms in front (to maintain stock alignment specs). This will give you the effect you are looking for. Tha advantage to doiing this IMO is that if you want to return to stock you only need to remove the upgrades and reinstall you stock pieces ( you DO keep you OEM stuff...right??). That was my perspective in my earlier reply. Again just my
Like Kelly said, that depends on the offsetof the wheels. With all those mods, you will definitely rub with a wide tire/aggresssive offset. I have 285s in the back, with spacers on my wheels that puts them at the equivalent offset of +19 10.5" volks. I also have adjustible rear camber (at -.8 deg), which actually makes rubbing even MORE of an issue.
Old Apr 6, 2006 | 09:17 AM
Auto RnD's Avatar
Auto RnD
Ok so rolling fenders helps out when you run too agressive of an offset or too agressive in terms of tire sizing
That is after the roll before the roll don't even think about driving it like that =)
Old Apr 6, 2006 | 09:24 AM
kcobean's Avatar
kcobean
Now THAT is slammed...do you rub under hard cornering when the suspension is compressed?
Old Apr 6, 2006 | 09:35 AM
GQ 350z's Avatar
GQ 350z
That's sick. I'll be doing some pretty extreme stuff myself too, hopefully by this weekend.
Pretty much what has already been said--roll them to fit extreme offsets or extreme tire sizes
Old Apr 20, 2006 | 08:10 AM
ecorona6's Avatar
ecorona6
Does any one know if I can fit some Volks 19x8.5 +29 and 19x9.5 +34 on my Z? Found them for a good price, but I am concerned about the offset.
-Edgar
Old Apr 20, 2006 | 11:19 AM
kcobean's Avatar
kcobean
-Edgar
My offsets are +15 and +20 on the same width/diameter wheels. I'm REALLY close to rubbing, but I don't. I think you'd have issues with those since there basically another 1.5mm out in the front and rear.
Old Apr 20, 2006 | 02:16 PM
LastODJedi's Avatar
LastODJedi
§ith Mã§t€®
I rolled my 510's fenders with a baseball bat. It was nothing and took about 5 min to do it. And that was back in '88 or '89. Granted, it was only a 510.
Old Apr 21, 2006 | 09:57 AM
Auto RnD's Avatar
Auto RnD
8.5 +29 and 9.5 +34
That will fit but it wont be near as flush you will definitely need some spacers. =)
Old Apr 21, 2006 | 12:05 PM
accordfreak's Avatar
accordfreak
8.5 +29 and 9.5 +34
does your tires rub the front plastic fender wheel well lining?
Old Apr 22, 2006 | 08:50 AM
kuo246's Avatar
kuo246
I rolled my fenders my self the key is patience when heating up the rolling surface, either with a hair dryer or heat gun. if you do use a heat gun keep it on low because you could bubble/boil your paint!
i used www.rollyourfender.com great guy and for $50 roll all of your fenders
now i have 295 30 19 on the rears with no rubbing what so ever!
Obadabot
Jun 18, 2023 11:31 PM
Justin100
Nov 25, 2021 06:26 AM
