Removing the Rear Wiper
Old Apr 12, 2006 | 05:06 AM
sry110's Avatar
sry110
Default Removing the Rear Wiper
Hey folks...
I just picked my car up from the dealer's body shop because they were fixing some paint damage that occurred while the car was in transit from Japan. Anyway, when I got to the dealer I inspected the paint and everything was to my satisfaction, so I went on my way. Then while I am driving, I noticed that my rearward view was more obstructed than usual, and I realized that the rear wiper was laying across the window (from side to side of the car) instead of its normal position (along the length of the car). Those morons took off the wiper and put it back on 90 degrees from where it should go! The paint damage was on the hatch, so they had to remove the wiper and glass to repaint the entire thing.
So obviously now if I turn on my rear wiper, it will trill to sweep toward the rear of the car and either scrape along the rear deck, or burn the motor up if it can't get up over the weather stripping. Anyway, I need to take the wiper off and put it back in its normal position, but I can't find anything in the owner's manual telling/showing how to accomplish that. Can anyone give me some insight on this one?
NOTE: It is not an issue of the wiper blades being installed incorrectly (I can handle that...), it is the entire wiper arm assembly.
Thanks...
Steve
Old Apr 12, 2006 | 05:11 AM
angelico's Avatar
angelico
Just unscrew the nut on the bottom of the arm, pop it off and but it in position and screw it back in. Its really that easy, Nissan did the same damn thing to me, I tell you what else it doesnt make them seem like rocket Scientists does it.
Old Apr 12, 2006 | 05:21 AM
sry110's Avatar
sry110
Thanks for the quick reply...
I just went back out to my car to look for that nut...can't seem to find it. Where exactly on the wiper arm is it? Down by the pivot point? And I am assuming it's a very small black hex nut?
Thanks again!
Steve
Old Apr 12, 2006 | 05:22 AM
350Z007's Avatar
350Z007
You probably have to take off the cap on the end of the wiper arm to see it. Just a guess.
Old Apr 12, 2006 | 05:29 AM
angelico's Avatar
angelico
You cant miss it, just pop off the cap where the wiper meets the body of the car.
Old Apr 12, 2006 | 09:27 AM
usmanasif's Avatar
usmanasif
Directions are here: https://my350z.com/forum/showthread....=wiper+removal
Old Apr 12, 2006 | 09:43 AM
sry110's Avatar
sry110
Originally Posted by usmanasif
hmmm...well I sort of followed those instructions...except once I removed the nut, I just rotated the wiper arm until it was in the right position. It did required some force to make the arm rotate, but it went nonetheless. Then I replaced the nut and put the cover back on, then turned on the wiper to test. It seemed to sweep back and forth as intended without making any strange noises, so hopefully it is ok. I am just hoping that I didn't damage anything in the wiper mechanism when I rotated the arm, but chances are good that it broke friction between the wiper arm thru hole and the shoulder on the pivot stud before it damaged the motor mechanism. I guess time will tell.
Thanks for the help guys!
-steve
Old Apr 12, 2006 | 11:06 AM
Clapton9286's Avatar
Clapton9286
Steve- How easy was it to find everything? I'm considering taking the whole damn thing off myself.
Dylan
Old Apr 12, 2006 | 12:43 PM
sry110's Avatar
sry110
Dylan
It was simple to find the nut and take it off, and I guess if I had spent enough time tugging on the thing it would have popped right off the mounting post. As far as removing it, you would have to take out the plastic lining on the inside of the hatch to get to the mechanism, and I think someone above posted a link with instructions for doing that. I was also considering removing it and putting a cap or something to fill in the empty space.
Old Apr 12, 2006 | 12:49 PM
Clapton9286
Yea. If you do, let me know. It'd be a good weekend project, lol.
Dylan
Old Apr 12, 2006 | 02:48 PM
Silkk's Avatar
Silkk
Great how-to. I'll be removing mine this weekend...
Old Apr 13, 2006 | 12:21 AM
Z_Driver's Avatar
Z_Driver
Master
Dylan
Shouldn't take more than an hour or so including painting the plug.
Old Apr 13, 2006 | 08:17 AM
Clapton9286
Does the plug come in black?
My only worry is putting it back on..lol...hows it in the rain? i only use it sometimes anyway, and I never had one before with my old Z.
Old Apr 13, 2006 | 08:25 AM
Z_Driver's Avatar
Z_Driver
Master
Yep, it comes in black nylon. Use some exterior black silicone adhesive around the hole prior to installation. In that way you will make sure that no water or dust get in your car around the plug.
I painted mine with a cheap spray can. Came out looking great. Metal flakes and all.
Old Apr 13, 2006 | 08:26 AM
Clapton9286
Ah ok. Has it been in the rain though? And how is it in the rain? Or would I need to Rain X it every month.
Old Apr 13, 2006 | 08:27 AM
Santacruzslick's Avatar
Santacruzslick
Veteran
I'm gonna have to agree and say just take it off and leave it. If you polish your glass with whatever you use on your paint it'll work like rain-x(without that damn residue). There's no need for a wiper back there...
Old Apr 13, 2006 | 08:37 AM
Clapton9286
Alrighty...that sounds good...hmm..maybe this weekend!
That plug can't expensive, can it? lol
Old Apr 14, 2006 | 10:13 AM
1nate7's Avatar
1nate7
You can try this for free: https://my350z.com/forum/exterior-and-interior/153918-rear-wiper-removal-new-cover-found.html
Since you have a black car, you might not even have to paint it.
3vilbunny
Jul 18, 2017 05:10 PM
kyin
Oct 15, 2015 05:54 AM
