Bondo or Fiberglass in-fill?
Old Apr 26, 2006 | 09:19 AM
james840a's Avatar
james840a
Default Bondo or Fiberglass in-fill?
Ok, i got the materails to do it ether way. If i do the fiberglass id have todo layers to infill the lic. plate area. If i use Bondo, i can infill it all and shape it better since it is a paste. Fiberglass would be a little more messier. What do you guys thing? Its not a deep infill its about .5 on the sides and inch in the middle.
Old Apr 26, 2006 | 10:05 AM
B-Unit's Avatar
B-Unit
just keep in mind bondo will add ALLOT of weight as opposed to fg cuz its much denser.
You need a better pic tho, i cant really see what ur talking about
=B=
Old Apr 26, 2006 | 10:38 AM
james840a's Avatar
james840a
Im thinking it wont be alot of weight just filling in a recessed area for the Lic plate, I attached couple picture, i dont have my camera here with me. But my bumber is right behind me at work. The top edge that is recessed is a 1/4"
Attached Thumbnails Bondo or Fiberglass in-fill?-bondoorfiber.jpg   Bondo or Fiberglass in-fill?-bondoarea1.jpg
Old Apr 26, 2006 | 12:43 PM
james840a's Avatar
james840a
Ok, i came up with an idea. What ill do is not molde it in but make a sepperate peace that would bolt to the location. That way if i need to put on the lic. i can. Im going to make the peace to fit in this area nice so there isnt to much of a seam. This bumber flexes and can flex right there, so i dont want it to mess up the paint.
Old Apr 26, 2006 | 01:11 PM
fonzy's Avatar
fonzy
That White Z Looks A Porsche
Old Apr 26, 2006 | 01:29 PM
illudezion's Avatar
illudezion
what material is the bumper made of? If fiberglass use fiberglass and if its urethane use urethane filler
Old Apr 26, 2006 | 02:24 PM
james840a's Avatar
james840a
the bumber is made of a Hybid fiberglass.
Old Apr 26, 2006 | 02:31 PM
B-Unit's Avatar
B-Unit
allright that second pic helps a bunch, just use body filler for the job.
-B-
Old Apr 26, 2006 | 03:40 PM
illudezion's Avatar
illudezion
use fiberglass then.
Old Apr 26, 2006 | 06:00 PM
james840a's Avatar
james840a
i started the fiberglass, This fiberglass jelly is as thick as the bondo.
Old Apr 26, 2006 | 09:00 PM
JDMFairlady21's Avatar
JDMFairlady21
wow let us see the whole thing man! i've been aching to see this kit. =)
Old Apr 26, 2006 | 09:36 PM
illudezion's Avatar
illudezion
yeah it's good stuff better then using bondo...cus if you did after a few bumps it'll just fall off
Old Apr 27, 2006 | 06:18 AM
james840a's Avatar
james840a
Here is just the front, Not painted yet. This was my test fitment. I only went with the front bumber.
Old Apr 27, 2006 | 06:04 PM
james840a's Avatar
james840a
Ok got it filled in, now have to sand it smooth, check for low spots
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
dcains
Sep 21, 2015 09:28 AM
Encore
Audio Builds
69
Sep 29, 2008 05:50 PM
03 Z for ME
May 7, 2003 06:00 PM
