Is this Emblem salvagable?
I bought this used Z emblem from a forum member and this is what I discovered on the backside of the emblem. Is it salvagable? If so, what can I do to make it ready to be put on the car?
Thanks.
Thanks.
Guest
Posts: n/a
or buy the kind that comes in the little roll with the red plastic backing. just cut off a few pieces and stick them in s crude out line of the emblem it doesnt have to be perfect. ive changed emblems about 3 times and this method has always worked for me
Originally Posted by ZlleH
So I buy a big sheet and use a knife to cut out the same emblem shape?
If you go to Wal-Mart's paint department where all of the tape is you'll find it there. It's labeled as double sided exterior mounting tape, look for the red liner seperateing the two sticky sides.
The best way to remove it from the emblem is to spray on adhesive remover to soften it up a bit then remove. Note( don't let the adhesive remover dry before attempting to remove)
Have fun!
Originally Posted by MustGoFastR
Where can you get sheets of the stuff if you want to try nd replicate the adhesive backing the emblem came with, as opposed to piecing one together?
At Super Wal-Mart the 1" wide roll is in the paint section of the store where all of the mounting tape is. The .5 inch wide one is keeped by the automotive side of the facility next to the body repair stuff.
What I would do is get the 1/2 inch one and put it on the emblems rear, cut off any excess or exposed tape with a sharp razor.
Vigman
Nov 17, 2015 04:34 AM
SpartanZ32
Oct 22, 2015 09:36 AM
hardkicks
Sep 20, 2015 12:28 PM
