clear sidemarker w/ led install with pics
Old Feb 8, 2003 | 03:49 PM
mysteriumZ's Avatar
mysteriumZ
Charter Member #101
Default clear sidemarker w/ led install with pics
hey guys, this is a follow up from skidazzle's diy led sidemarkers.
first, you must remove the tire and the wheel fender protector. i only had 1 jack so i had to do them 1 by 1, and the driver side is much easier than the passenger side. The fender piece is really easy to remove, and all you have to remove is the front half. There are 5 hex bolts on the under side, 3 plastic screws on the edge that you have to remove and couple plast pop in bolts. The fender protector is made of plastic, and its flexible, don't be afraid to bend them.
Attached Thumbnails clear sidemarker w/ led install  with pics-install-1.jpg
Old Feb 8, 2003 | 03:52 PM
mysteriumZ's Avatar
mysteriumZ
Charter Member #101
next, remove the orange sidemarkers with 2 screws.
this is a pic of the area after the fender has been removed, notice the head light area is also exposed. the black circle is where the sidemarker located.
Attached Thumbnails clear sidemarker w/ led install  with pics-install2.jpg
Old Feb 8, 2003 | 03:53 PM
mysteriumZ's Avatar
mysteriumZ
Charter Member #101
take out the orange sidemarker and replace with clearones w/ leds.
Attached Thumbnails clear sidemarker w/ led install  with pics-install3.jpg
Old Feb 8, 2003 | 03:56 PM
mysteriumZ's Avatar
mysteriumZ
Charter Member #101
next locate the parking light bulb, its the one next to the xeon lamp housing with a green/white wire and a black wire. the green/white one is the positive and the black is ground. this is where i tap in power for the leds.
its the black circle in the pic
Old Feb 8, 2003 | 04:00 PM
mysteriumZ's Avatar
mysteriumZ
Charter Member #101
i got the tap in piece from radio shock it works for wires from 14-20 gauges. about 2.50 fro 10 of them. tap in the positive to the green/white wire. for the ground you have 2 options, you can tap in the black wire, which is what i did, or you can connect the negative end to the chassis.
Attached Thumbnails clear sidemarker w/ led install  with pics-install-4.jpg
Old Feb 8, 2003 | 04:14 PM
mysteriumZ's Avatar
mysteriumZ
Charter Member #101
another pic of the wire connection from the parking/city lights.
i also changed the parking/city light with a white led bulb.
Attached Thumbnails clear sidemarker w/ led install  with pics-install-5.jpg
Old Feb 8, 2003 | 04:21 PM
mysteriumZ's Avatar
mysteriumZ
Charter Member #101
for the passenger side, its much harder. you have 2 options, 1 is to remove the bumper completely. or you can losen up most of the screws on the passenger side bumper, and access the sidemarker from under side. There is a bumper removal diy on the forum written by skidazzle, so i'm not going to post pics.
The wire connection is the same for both side. The job took me about 3-4 hours, and i had no experience on this at all prior to today.
last, i like to thank skidazzle for his well written diy on the making of the sidemarker with leds.
Old Feb 8, 2003 | 04:22 PM
mysteriumZ's Avatar
mysteriumZ
Charter Member #101
here are some pic of the results.
Attached Thumbnails clear sidemarker w/ led install  with pics-1.jpg
Old Feb 8, 2003 | 04:23 PM
mysteriumZ's Avatar
mysteriumZ
Charter Member #101
another
Old Feb 8, 2003 | 04:24 PM
mysteriumZ's Avatar
mysteriumZ
Charter Member #101
close up
Attached Thumbnails clear sidemarker w/ led install  with pics-3.jpg
Old Feb 8, 2003 | 04:27 PM
mysteriumZ's Avatar
mysteriumZ
Charter Member #101
last
Attached Thumbnails clear sidemarker w/ led install  with pics-5.jpg
Old Feb 8, 2003 | 04:29 PM
mysteriumZ's Avatar
mysteriumZ
Charter Member #101
forgot these
Attached Thumbnails clear sidemarker w/ led install  with pics-2.jpg
Old Feb 8, 2003 | 04:30 PM
rouxeny's Avatar
rouxeny
Wow, looks very nice. I like how they're white at night.
Old Feb 8, 2003 | 08:36 PM
SirMikel1's Avatar
SirMikel1
great job mysteriumZ! I love the way it looks, I haven't installed the ones you made for me yet but I hope to do so soon. We should get together again soon and maybe we can get it done. And take pics of the two Z's together of course
Old Feb 8, 2003 | 09:14 PM
md350z's Avatar
md350z
Default Clear Sidemarker
Where can you buy clear side marker??
Thanks,
Old Feb 9, 2003 | 04:10 PM
SirMikel1's Avatar
SirMikel1
Default Re: Clear Sidemarker
Thanks,
you can try www.strictlyz.com
aarrgghh
May 1, 2022 11:04 AM
BEBO'S ZEE
Jun 7, 2016 07:48 AM
davidm350
Oct 31, 2015 02:28 PM
3oh5z
Exterior
Sep 22, 2015 10:09 AM
