Passenger Window comes down 1/3 automatically. Why?
Old May 10, 2006 | 09:32 AM
DanOnTheRoad's Avatar
DanOnTheRoad
Default Passenger Window comes down 1/3 automatically. Why?
If my top is down and I click the auto up for the windows both my windows will go up, then my passenger side will drop down about 3 inches and stop. I then have to push up again to bring it to the top.
Anyone else have this issue and or fix?
Old May 10, 2006 | 09:47 AM
Silkk's Avatar
Silkk
Mine is currently doing some weird stuff do. It normally drops 1/4" when the door is opened, then back up after the door is closed.
It is now dropping 2" and not going back up. It will not go back up even with the switch until I push down first. I am thinking something in the window switch got messed up as I was playing around with the doorskin off to install new mirrors. I may need to disassemble again this week and make sure that switch and all wires are working correctly.
Old May 10, 2006 | 09:54 AM
DanOnTheRoad
hmm, issue is I haven't messed with anything. It just started doing this on it's own. We'll I have to go in for an oil change, so I'll just ask them. It's brand new, so shouldn't be an issue.
Old May 10, 2006 | 10:21 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Look in maintenance this is a well known issue with our Z's, mine does it as well. I need to get inside th edoor panel and adjust the stop, not worth leaving the car at the dealership 1 day for it....
Old May 10, 2006 | 10:54 AM
atlsupdawg#2's Avatar
atlsupdawg#2
My driver window does this as well but I did have the whole door replaced and I doubt the body shop adjusted whatever needed to be adjusted. What bothers me the most is that my windows will creep down while I'm driving and the wind noise is irritating.
Old May 10, 2006 | 11:19 AM
kbomb's Avatar
kbomb
Mine too! It's a known thing. I thought it was more related to cold weather but now its spring. Kind of ghetto but to get the window to stay up, I just scroll it all the way up and use the lock window feature for the passenger side.
Old May 10, 2006 | 11:25 AM
Ahsmo's Avatar
Ahsmo
Imakecopies
https://my350z.com/forum/showthread....ht=window+drop
Old May 10, 2006 | 01:11 PM
IceBurnzTT's Avatar
IceBurnzTT
YAY Nissan.....
Old May 10, 2006 | 02:17 PM
drifter23's Avatar
drifter23
Motor/regulator replacement will fix your problems. I just had mine done at the dealership. If you are still under warranty it will be free of charge. And if you have the extended warranty you will most likely be charge a $50 deductible.
Here is a link from the Nissan help website:
http://www.nissanhelp.com/Ownership/.../NTB04-040.htm
Old May 11, 2006 | 11:51 AM
DanOnTheRoad
Oh I'm definitely under warranty. I only have 6K on my car! LOL
Old May 13, 2006 | 04:59 PM
___DJK___'s Avatar
___DJK___
The motor/regulator thingie needs to be reset. This is a common problem on all Nissan/Infinitis with the autoup feature.
Rev_Night
Nov 7, 2020 06:00 PM
Siqcology
Sep 18, 2019 01:45 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
samansharif
Sep 25, 2015 12:31 PM
