Question on installing the stillen wing
on
Guys i just wanted to know is it necessary to use bolts and drill holes to the hatch to install the stillen wing or can it be done safely with double sided tape.
http://stillen.com/product_detail.aspx?sku=1035059
on
If it had the factory wing the holes are already there....Just use two 10mm bolts with the 3M tape......If not you can just use the 3M tape it will hold just fine, make sure that you prep the area first...Good luck.
on
on
no im talking about the hatch wing not the roof wing. Thanks alot guys
Originally Posted by IceBurnzTT
I think they op is refering to the roof wing above the rear windshield
Bodyboarder81
09-21-2015 06:23 AM
