Painting...
Old Aug 16, 2006 | 11:51 PM
creationv2's Avatar
creationv2
Default Painting...
all right i could be wrong but i have looked around, i have seen it, but i havent seen any explanations ....
first how do you remove the antenna base?
second how do you go about painting it?
thanks in advance
Old Aug 17, 2006 | 12:13 AM
kumdolife88's Avatar
kumdolife88
Old Aug 17, 2006 | 05:17 AM
03Zilverstone's Avatar
03Zilverstone
After you take the antenna off you will need some channel locks and a rag. There is a little metal piece above the base. It should have two slots in it. Use the channel locks to screw it off using the rag to protect it. Then just pull the base out after you get the metal piece screwed off. Spray it with some adhesion promoter about 5 minutes before you paint it.
Old Aug 17, 2006 | 02:19 PM
creationv2's Avatar
creationv2
great great thanks a lot man....but so i dont have to use any type of sand paper or anything? and if i was painting my antenna is it the same thing with just the promoter?
Old Aug 17, 2006 | 04:33 PM
03Zilverstone
Just make sure you clean the base off real good. For the actual antenna you need to scuff it with a red scotch pad from an auto body retailer. After it's all been scuffed you can wipe it down good and spray it.
For any raw plastic all you have to do is wipe it down good (ideally with a PPG prep wipe) then spray it with the adhesion promoter.
Old Aug 18, 2006 | 11:54 AM
creationv2's Avatar
creationv2
thanks again brah, ill go and try this out sooon
Old Aug 18, 2006 | 07:04 PM
B-Unit's Avatar
B-Unit
Brah = ?
Old Aug 18, 2006 | 07:42 PM
iceman21_23's Avatar
iceman21_23
brah= bro
m0nkie
Southern California
Nov 21, 2008 05:54 PM
RAYZ33
May 9, 2008 06:43 PM
Christian88
Sep 14, 2007 04:21 PM
