need pics of 06 headlights turned on
Old Aug 18, 2006 | 07:39 PM
sorphin's Avatar
sorphin
Originally Posted by John@Victory
what are you driving? 06 or retro?
genuine 06
Old Aug 18, 2006 | 07:40 PM
Built2shredZ's Avatar
Built2shredZ
So do you think if I put my 04' amber bulb in my 06' headlight that would fix the problem???
Old Aug 18, 2006 | 07:58 PM
kourosH's Avatar
kourosH
here
Old Aug 18, 2006 | 08:05 PM
TiPIACE's Avatar
TiPIACE
ive got the 06 headlights on my 05 and the indicators/turn signals stay off with the light on
the 4 led amber strip are on when the parker/headlight is on
you've prob just wired them up wrong. I dont think its the globe. I put chrome indicator bulbs in afterwards and they work just like the standard orange ones
Old Aug 19, 2006 | 04:04 AM
John@Victory's Avatar
John@Victory
how would we wire them wrong? its 1 clip and your done
Old Aug 19, 2006 | 05:56 AM
TiPIACE's Avatar
TiPIACE
im not the one with permanently illuminated turn signals
Old Aug 19, 2006 | 06:01 AM
John@Victory
obviously you have no working knowledge of how our cars are put together.
if you did you would know it is plug and play.
1 plug that only allows it to be plugged 1 way.
there is no wireing to be done.
someone with working knowledge of the car would know that.
now if you dont have anything helpfull to contribute as to why they stay lit on U.S. spec cars, then please dont post
Old Aug 22, 2006 | 03:48 PM
Built2shredZ
Ok, I installed my 06's headlights in my 04' Roadster and I have the same problem with the turn signal bulb staying on... I thought about putting my 04' bulb in but the 06' bulb has a grey plastic piece that snaps onto the end of the bulb and then the plastic part snaps into the wire harness. Other than that the shape and size of the bulbs are the same, except the 06' one has two filament and the 04' only has one.
I thought about trying to take the plastic part of the 06' bulb but didnt want to chance breaking it.... I might go ahead and order and 06' replacement bulb and try and remove the plastic part off of that one and then snap it on the 04' bulb...
If anyone comes up with any better ideas let me know..
Old Aug 31, 2006 | 10:06 AM
THE TECH's Avatar
THE TECH
I'd like to know about this too. Just installed the 06 in my 03 and the parking/turn signal is on all the time...yuck. I'll try getting a single filament one today and see what happens.
Old Aug 31, 2006 | 12:10 PM
davidf's Avatar
davidf
My park lamps are on when my headlights are on, though I've recently clipped the wire to kill them as I did'nt like all that yellow with them on. My car is 03 with 06 lamps, and yes the original were fact. xenon.
Old Oct 4, 2006 | 04:22 PM
Built2shredZ
Which wire do you clip to disable parking lamp?
Old Oct 4, 2006 | 05:43 PM
NeptuneZ's Avatar
NeptuneZ
Did anyone figure this out yet? I want to get '06 lights on my '03, but I don't want to have these problems.
Thanks
Kaue
Old Oct 4, 2006 | 07:11 PM
Built2shredZ
Being turn signal bulbs are cheap Ill give it a shot tomorrow and see what happens...
Old Oct 4, 2006 | 10:16 PM
deviljon's Avatar
deviljon
hey treez where did you purchase chrome turn signal bulbs from?
Old Oct 5, 2006 | 06:15 AM
THE TECH's Avatar
THE TECH
Just cut one of the wires on it. Beware though that the bulb can be put in two different ways. So when you cut the wire and you think that it doesn't work when you put it back in, pull it out and turn it around and try it again.
Old Oct 18, 2006 | 06:35 PM
SixRB6's Avatar
SixRB6
If someone figures this out I need to know as well...I just oreder $1,500 worth of 06 headlights and tails!!
I am bummin reading this
Old Oct 19, 2006 | 02:49 AM
TiPIACE's Avatar
TiPIACE
am i too late
this is retro fit onto my 05 Ann which in Aus came with halogens. No indicator illuminated when on
Old Oct 19, 2006 | 01:59 PM
  #38
old_s13's Avatar
old_s13
Fact:
03-05 HID-spec headlamps use a single filament bulb for turn signal function.
Bulb type: WY21W
06-XX HID-spec headlamps use a dual filament bulb for parking/signal function.
Bulb type: 3157NA
If your car illuminates the signal dimly as a parking lamp, that can easily be resolved by simply clipping ONE of the wires that goes to the signal bulb. If notes are correct, the color of the wire is blue.
Cheers!
Mike / ClearCorners.Com
