Hood dampers on fiberglass hood?
Old Aug 27, 2006 | 08:00 AM
roncfpz's Avatar
roncfpz
Question Hood dampers on fiberglass hood?
Has anyone installed hood dampers on a fiberglass hood and, if so, any problems? I have a Veilside V3 hood and just bought the CTD hood dampers from www.courtesynissanparts.com but they feel too stiff and I'm afraid the hood may start to crack. The only other option for lightwieght hoods are the dampers from Top Secret which are about $400.
BTW, these are very nice dampers and do NOT require the covers to be trimmed.
Thanks!
Old Aug 27, 2006 | 09:19 AM
Ghost_shift's Avatar
Ghost_shift
Thanks!
You cant put dampers on a CF hood. The resistance is too great and will crack the hood in the corners.
Old Aug 27, 2006 | 11:08 AM
taurran's Avatar
taurran
I have a fiberglass hood as well, and I don't think it would be a good idea to put them on it. IMO, it would be best to stay stock or find something else that can support it from the front end.
Old Aug 27, 2006 | 02:29 PM
tonester1011's Avatar
tonester1011
CF God
ive had them on my cf hood for over a year and have had no problems at all...
Old Aug 28, 2006 | 05:50 AM
roncfpz's Avatar
roncfpz
Anyone else? I contacted CTD and they indicated if the Veilside V3 hood is the same weight as factory there should not be any problems.
Anyone know if the Veilside V3 is the same weight as the factory hood? I believe it is very close but maybe a little lighter.
Old Aug 28, 2006 | 05:51 AM
roncfpz's Avatar
roncfpz
Which dampers do you have? TEIN?
Thanks!
Old Aug 28, 2006 | 05:53 AM
tonester1011
CF God
theyre not tein...i got them from a member on here a whille ago and i dont remember the name of them...sorry, but they cant be much different from tein so i dont see there being a problem...
Old Aug 28, 2006 | 06:05 AM
roncfpz's Avatar
roncfpz
Thanks again, much appreciated.
Old Oct 1, 2006 | 10:13 AM
ZPirate's Avatar
ZPirate
Thanks!
Did you install the CTD hood dampers? I have looked around and they look like the best ones for the regular 350Z hood. They are just expensive when compared to others. I guess I will just have to bite the bullet and buy them from Courtesy.
Old Oct 1, 2006 | 09:06 PM
roncfpz's Avatar
roncfpz
Yes, they fit fine and no trimming.
Old Oct 1, 2006 | 10:10 PM
G352NV's Avatar
G352NV
I had em on my CF hood. No problems at all.
Old Nov 2, 2006 | 06:20 PM
Agentman03's Avatar
Agentman03
hOW ABOUT SOME PICTURES OF THE VEILSIDE V3 HOOD .. aNY ISSUES ? gLAS OR CARBON ..VEILSDE OR GTP MFG. ???
Old Nov 2, 2006 | 06:34 PM
THE TECH's Avatar
THE TECH
Do some searching...relax on the caps.
Old Nov 2, 2006 | 06:38 PM
THE TECH's Avatar
THE TECH
I'm gonna test out the Teins on the Seibon and see how it goes.
Old Jul 25, 2007 | 07:51 AM
Risky_Business's Avatar
Risky_Business
Quadrant 987c
Default I would think...
that since the Seibon and many other carbon fiber hoods are close to stock weight that the dampers should be ok (as some have mentioned). This is what I intend to do.
Old Jul 25, 2007 | 03:12 PM
VIZAGE's Avatar
VIZAGE
This is kind of an old thread. I have the shocks from Courtesy with an Seibon CF hood. At first the shocks are really stiff. But they eventually wear a little and start to become easier to close. Just be careful for the first few months.
Old Jul 25, 2007 | 03:56 PM
Risky_Business
Quadrant 987c
Default Yeah...thread is old for sure...
this is exactly what I am about to do. Shocks from Courtesy are crazy stiff out of the box. Should I be doing anything to relax them a bit...?
Old Jul 26, 2007 | 05:27 PM
VIZAGE's Avatar
VIZAGE
Not really. Just needs to be careful when close the hood for awhile. You'll know when there broken in. You can hardly compress them by hand out of the box. But I should add that for the break in period, make sure you use both hands spread out on the hood to close. This adds even pressure on both sides of hood while closing.
Old Jul 26, 2007 | 07:45 PM
JDMZ33's Avatar
JDMZ33
Vendor - Former Vendor
Check out our hood damper upper bracket. As you can see it is bolt on top of the factory metal bracket. So the weight force of the damper is pushing on the bracket, not on the hood. Check photo below
Old Jul 26, 2007 | 07:48 PM
JDMZ33's Avatar
JDMZ33
