Top Secret Light Weight Hood Dampers (pics)
Old Sep 8, 2006 | 11:01 AM
roncfpz's Avatar
roncfpz
Thumbs up Top Secret Light Weight Hood Dampers (pics)
I finally found a set of hood dampers that can be used on lightweight carbon fiber or FRP hoods AND no major cutting of the plastic brake and battery covers. The only cutting necessary is a small half circle on the outter edge of the plastic covers for the mounting bolt. This is a very simple install.
I had previously tried using the dampers from NRG Innovations and CTG/Courtesy Nissan but they were too stiff for a lightweight hood and could eventually cause cracks. I didn't want to take any chances. I could feel a slight yet noticeable difference between these dampers. These also seemed a little beefier than the other two options. The dampers are not cheap (about $350) but definitely work well on my Veilside V3 fiberglass hood. Also, these hood dampers for the G35 but they work perfect on the Z as well. I purchased them from www.driftfactory.com. Oh yeah, eventually these will be painted to match the color scheme of the car.
Attached Thumbnails Top Secret Light Weight Hood Dampers (pics)-img_2083.jpg   Top Secret Light Weight Hood Dampers (pics)-img_2085.jpg
Old Sep 8, 2006 | 11:08 AM
Rickdogg's Avatar
Rickdogg
Out of hiatus
Your car is clean man! Thumbs up again
Old Sep 8, 2006 | 11:12 AM
roncfpz's Avatar
roncfpz
Thanks Rick!
VIP-STATUS's Avatar
VIP-STATUS
Thumbs up
NICE!
Old Sep 8, 2006 | 11:21 AM
Chebosto's Avatar
Chebosto
how much lighter is your hood compared to stock?
a majority of the hoods i've seen actually weigh more than stock...
i'm curious if the NRG or the courtesy ones were overvalved.. are you meaning that the hood flexes when you try to close it, hence the cracks?
$350 is stiff for replacement of a $5 homedepot dowel! hehe ;P
Old Sep 8, 2006 | 12:08 PM
roncfpz's Avatar
roncfpz
I believe the Veilside is a few pounds lighter (maybe 2 or 3lbs). I don't know for sure since I never weighed either, but I recall a post mentioning that slight difference. More importantly, the Veilside feels much more flexible and not nearly as rigid as stock. With the NRG and CTD dampers the hood would flex much more than with the Top Secret at or above the mounting points.
Also, I know it was expensive but the hood prop just plain sucks. If I placed it in the stock location hole when raised my hood would be very crooked. The slighest wind could knock it off and cause damage. This actually happened at the Spring Break Nationals but luckily the hood was caught before it came back down. Also, if I stuck the prop in the middle opening (hood latch) it was starting to dent the hood especially in the hot Florida sun. In the end, pricey but effective. And now I can say I have some Top Secret stuff on my car. hehe
Old Sep 8, 2006 | 12:29 PM
driftk1d's Avatar
driftk1d
Old Sep 8, 2006 | 02:09 PM
Nitrouz's Avatar
Nitrouz
Back to Z
thanx! I need to buy a set...
Old Sep 9, 2006 | 12:02 AM
Volk350Z's Avatar
Volk350Z
Master
nice...
Old Sep 9, 2006 | 12:08 AM
GTNPU Z's Avatar
GTNPU Z
VERTEX Army CEO
Sweet! I like the fact that you don't have to modify your battery/fluid cover bases.
Old Sep 9, 2006 | 06:59 AM
jinsei888's Avatar
jinsei888
leave em gold, it's toight!
Old Sep 9, 2006 | 10:20 AM
Zexy's Avatar
Zexy
Heck no Ron. You don't paint over Top Secret Gold.
You crazy meng.
Old Sep 9, 2006 | 05:04 PM
Voboy's Avatar
Voboy
You crazy meng.
Would go great with a Black car!
Old Sep 9, 2006 | 11:21 PM
Z350Lover's Avatar
Z350Lover
nice... really nice and clean damper setup... love it!
cheers,
richie
Old Sep 10, 2006 | 02:56 AM
roncfpz's Avatar
roncfpz
Thanks guys! I may just keep 'em gold.
Old Sep 10, 2006 | 10:53 AM
Chineseguy's Avatar
Chineseguy
yea keep the gold. it looks too nice
Old Sep 10, 2006 | 10:55 AM
Nitrouz's Avatar
Nitrouz
Back to Z
definitely keep the gold! Looks sweet as hell!
Old Sep 10, 2006 | 11:39 AM
G352NV's Avatar
G352NV
Tein's work just as well. They can be modded so no cutting is needed. I bought mine for 80.00 shipped from a vendor.
Old Sep 10, 2006 | 03:56 PM
brigz's Avatar
brigz
$350? WOW thats cool
Old Sep 10, 2006 | 04:21 PM
roncfpz's Avatar
roncfpz
With stock or fiberglass hood? I contacted TEIN and they did not recommend them for my hood.
