Apparently There Is A Wrong Way To Install HIDs
Old Sep 22, 2006 | 08:13 PM
RiotWithin's Avatar
RiotWithin
Default Apparently There Is A Wrong Way To Install HIDs
I just recived my "OEM" 8000k HIDs. It looks horrible on the road and instead of a strait line it bows upward... I don't feel like messing with them because it's such a pain to get to them. Should I go to the stealership or does anyone know the proper way to install them?
Old Sep 22, 2006 | 08:15 PM
Todd350ZX's Avatar
Todd350ZX
Didn't you have to drop the front bumper to replace the assembly?
Old Sep 22, 2006 | 08:27 PM
Nic@CiNcity's Avatar
Nic@CiNcity
You probably put them in wrong? Are they just bulbs, or the entire housing?
Old Sep 22, 2006 | 08:32 PM
Nic@CiNcity
it's really not hard to adjust them though. Has two screw type things that push and pull the housing in the correct direction. I've never messed with it while it was in the car, but have taken them apart and painted several and they all turn out straight as an arrow.
Old Sep 22, 2006 | 10:34 PM
ZlleH's Avatar
ZlleH
Sorry, but what do you mean "OEM" 8000K HID?
There's an OEM HID that is 8000K?
Old Sep 22, 2006 | 11:23 PM
Built2shredZ's Avatar
Built2shredZ
Here you go...
https://my350z.com/forum/350z-roadster/215523-door-pannel-removal-zr.html
Old Sep 22, 2006 | 11:55 PM
usmanasif's Avatar
usmanasif
There is no such thing. Either it is OEM, or burns at 8000K; can't be both.
Old Sep 23, 2006 | 12:06 AM
Derratte's Avatar
Derratte
Most 8000K and higher HID systems are actually dimmer than the stock halogen bulbs. If you want brighter headlights, you need to stick with the OEM 4300k systems.
Old Sep 23, 2006 | 04:14 AM
RiotWithin's Avatar
RiotWithin
Thanks, I typed "OEM" because these were direct replacements that didn't need a new ballast.
Old Sep 23, 2006 | 09:03 AM
ZlleH's Avatar
ZlleH
Ah, so you basically just bought a bulb.
Old Sep 23, 2006 | 11:29 AM
RiotWithin's Avatar
RiotWithin
I had 8000k HIDs on my Magnum, and they were far brighter on the road than the stock Z HIDs. I just wish these worked right the first time. I can't even get the front clips off the bumber to install them properly. I had to go through the wheel well, it's very tight in there!!!
Old Sep 23, 2006 | 11:39 AM
RiotWithin's Avatar
RiotWithin
I D\L the manual from the link. What kind of tool do I need to adjust the adjuster screw??? I think I see it but I doubt I have what I need...
Old Sep 23, 2006 | 03:36 PM
umzzz's Avatar
umzzz
Cwest Army
i had tihs problem when i put my hid bulbs back in but i just had them upside down...take them out and rotate the bulb 180 and reinstall them...you should be good to go. i believe the shaded part of the bulb should be at the top.
Old Sep 23, 2006 | 04:43 PM
davidf's Avatar
davidf
If they are direct replcement there is no need for level adjustment. I've changed countless HID bulbs for people. There are notches in the top of the bulb so fitment is precise, but it can be installed wrong if your not aware of it. Needless to say you'll have to remove them and place them correctly.
Old Sep 24, 2006 | 06:15 AM
RiotWithin's Avatar
RiotWithin
Okay, let me get this right before I atempt this again. On the boulb we have lets say a skinny tube, and a larger tube. The skinny should be on top, correct??? Oh and are the top bumber clips impossible to get off or is it just my car. I've even try prying it off with a hammer...
Old Sep 24, 2006 | 07:49 AM
davidf's Avatar
davidf
Sounds to me like you installed them in high beams. If so I don't know how the hell you got them to fit. And yes the thin tube like bulb goes in the top.
Old Sep 24, 2006 | 08:00 AM
RiotWithin's Avatar
RiotWithin
Figured it out... The person said these were direct replacements. WRONG. The factory bulb a a semi-circle notch then a square notch. The ones I got had square first then semi-circle. I got the dremil out and fixed it. Now it fits, but I have to wait until night to see if it worked or not...
Old Sep 24, 2006 | 08:18 AM
jinsei888's Avatar
jinsei888
I don't see how 8K can possibly give you better lighting range than the oem 4300s...haha that's just not how lighting temp logic works
Old Sep 24, 2006 | 09:14 AM
LightWerkz's Avatar
LightWerkz
you are correct, it cant. Scientifically its not possible.
People think it looks cool.
