Replacing my shift knob with nismo c/f, need help
You need to clamp on to the shifter shaft. The factory shift **** has some strong glue holding it in place so you have to turn it real hard to break the adhesion and then unscrew it. If you don't secure the shift shaft and you just turn the **** real hard you may hurt the shifter linkage. Search around here, I think I've seen pics.
Gary
Gary
Yeah they're on there pretty good huh. Hows the Nismo?
Originally Posted by slam
thanks, i figured it out...i just had to turn the **** VERY hard. I thought I was turning the entire shaft and screwing up my tranny.
Overall, I like the nismo **** better. It's not as comfortable to rest your hand on as the stock **** but shifts feels more positve with the nismo. It's hard to miss a gear with the nismo, and I like the slightly shorter throw from the nismo.
