painting front lip yourself (anybody tried this yourselves)
Old Oct 21, 2006 | 05:53 PM
smokedout350z's Avatar
smokedout350z
Default painting front lip yourself (anybody tried this yourselves)
anybody tried to paint the front lip by yourselves?????
Old Oct 21, 2006 | 06:17 PM
ofl0926's Avatar
ofl0926
with spray paint or with a compressor and a paint gun?
Old Oct 21, 2006 | 06:21 PM
smokedout350z
compressor,,my buddy hhas one but he's a rookie..i think its his dads
Old Oct 21, 2006 | 06:31 PM
GSXR-Z's Avatar
GSXR-Z
from what i have heard, you need a pretty big compressor or it will notcome out right since you have to waitso long forit to recharge between coats. Maybe since thefront lip is such a small piece as far as square volume, you could get away with say a 15 gallon tank. I just dont know about color matching.
Old Oct 21, 2006 | 07:35 PM
smokedout350z
thank you for the replies
Old Oct 21, 2006 | 08:29 PM
heleX's Avatar
heleX
Remember to try to keep a controlled environment when spraying and while its drying/hardening. You dont want any dust on there!
Old Oct 21, 2006 | 08:46 PM
steveiZdaman's Avatar
steveiZdaman
i leave the paint to the pros...very hard to match it perfectly and blend it and clear coat it
Old Oct 21, 2006 | 08:48 PM
smokedout350z
kool....i'll leave it to the pros....
Old Oct 21, 2006 | 08:49 PM
mr. sparco's Avatar
mr. sparco
15 gallons compressor?!
I use a 2 gallon Home Depot compressor. Anest Iwata LPH300 paint gun with a 1.3mm tip, PPG base/clear, 10 psi at the cap and 20 inline. Get a good spray gun and respirator. If you use a quality HVLP you won't need high pressure nor a large amount of air supply.
Old Oct 21, 2006 | 08:50 PM
smokedout350z
did you do it ur self^ ......is it e z???/// paint matchin probably be hard like the other guys above said
Old Oct 21, 2006 | 08:59 PM
Eazzy's Avatar
Eazzy
Iv painted many components and complete vehicles but I started when I was 12 and 30 + yrs has passed since then. I dont call myself a Paint and Body man, but I know more than many that call themselves that.
I could write a 100 page DIY book on painting a front lip, but experience is going to determain the outcome of it. Only way to lay down a durable Biatchin finish is to Fock up a few times.
Key elements are---A good HVLP Gun, A good moisture free air supply, An "Operating Room" atmosphere, A talent to lay paint, A knowledge of paints-primers-additives, Wet sanding and Buffing technics, and ----almost forgot---PATIENCE.
If u got 80% of that , u can paint ur Own front lip.
Old Oct 21, 2006 | 09:03 PM
Eazzy's Avatar
Eazzy
BTW ---Paint Matching is not hard if u got a good Paint Suppy Man and take him a piece off ur car----He will mix the Code then fine tune it
Old Oct 21, 2006 | 09:07 PM
smokedout350z
alrighty...maybe i'll try it myself one time
Old Oct 21, 2006 | 09:42 PM
Zincognito's Avatar
Zincognito
nope, something like this has to be left to the pros....
Obadabot
Jun 18, 2023 11:31 PM
