any tips on sealing headlight?
Old Oct 26, 2006 | 06:05 PM
excogitate's Avatar
excogitate
Default any tips on sealing headlight?
i painted it black inside and tried so hard to seal one of the head light, the other one got messed up on the lens. the one i tried so hard to seal leaks like there's no tomorrow, but the one i didn't seal doesn't leak at all...any tips on how to seal it properly? thanks
Old Oct 28, 2006 | 01:48 PM
bbs350z's Avatar
bbs350z
heat it up again, and pul it apart, and reseal it w/ a clear rtv sealant. just remember the tiny screws, screw them in after the rtv is applied, this will help it stay 2gether while its drying
Old Oct 28, 2006 | 01:58 PM
Eazzy's Avatar
Eazzy
Iv done several and have had small probs on a couple--I use the clear silicon but the prob with that is with the irregular contour of the perimeter---
Next set, Im going to use self leveling urethane caulk. Its great stuff iv used elsewhere. It is a little thinner, and flows to low spots in places that cant be reached with silicon, and levels perfectly flat. When it dries, Its very pliable and would be easy to disassemble if you need to later.
Actually --I believe that the original sealant is a urethan base rather than a silicon
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
sales@czp
Sep 23, 2019 03:30 PM
350z82
Oct 1, 2015 06:25 PM
JGee450
Sep 30, 2015 04:32 AM
