installing trunk gas shock...
Old Nov 5, 2006 | 12:44 PM
myZter's Avatar
myZter
PREMIER MEM.FTW
Default installing trunk gas shock...
i just got my trunk shock kit like this one http://mynismo.com/products/?id=4660&rsku=19843# how do you install it or do i have to take it to dealer?
Old Nov 5, 2006 | 12:45 PM
Mike Wazowski's Avatar
Mike Wazowski
to be honest. If you are asking how to install it you should take it to the dealer.
Old Nov 5, 2006 | 12:49 PM
myZter's Avatar
myZter
PREMIER MEM.FTW
yes i am asking how to install it. nobody here installed it themselves?
Old Nov 5, 2006 | 01:08 PM
Eazzy's Avatar
Eazzy
Does it not come with instructions??? Seems to me to be a pretty simple install
Old Nov 5, 2006 | 01:09 PM
redman333's Avatar
redman333
Hey give him a break. Not everybody knows how to work on their cars. There was a point that I would have asked that question just to know that I do it right the first time.
As far as installing new shocks I havn't swapped mine but I'm guessing its just a swap, pull the old ones off and put the new ones on the opposite way you took the others off.
Old Nov 5, 2006 | 01:26 PM
myZter's Avatar
myZter
PREMIER MEM.FTW
no instruction. ok i tried to pull it out but the round ball part just wont budge. how did you take it out?
Old Nov 5, 2006 | 01:30 PM
Eazzy's Avatar
Eazzy
U dont pull the ball out ---U unscrew the stud the ball goes into
Old Nov 5, 2006 | 01:34 PM
Eazzy's Avatar
Eazzy
Its a 12mm by the looks of it
Old Nov 5, 2006 | 01:47 PM
myZter's Avatar
myZter
PREMIER MEM.FTW
i only got these pair with nothing else. u cant unscrew the round part. you have to pull it out some how.
i already unscrewed the studs but the shock will no come out.
took quick pics with cell phone to its blury
Attached Thumbnails installing trunk gas shock...-photo134_000.jpg   installing trunk gas shock...-photo136_000.jpg   installing trunk gas shock...-photo138_000.jpg
Old Nov 5, 2006 | 02:07 PM
Eazzy's Avatar
Eazzy
Well ---u got me by the a$$ ---The ball appears to be crimped into the socket ----Put a yell out to one of the performance nissan guys ---I even pulled my bottom off
Old Nov 5, 2006 | 02:10 PM
Eazzy's Avatar
Eazzy
And the bottom bracket was a biach to put back on again
Old Nov 5, 2006 | 04:00 PM
myZter's Avatar
myZter
PREMIER MEM.FTW
i guess only dealer could install it then right.
Old Nov 5, 2006 | 04:33 PM
Eazzy's Avatar
Eazzy
First --I repeat ---Id ask one of the guys on the forum with Performance Nissan
I want to know myself---Generally a ball will pop out of a socket or has a slide lock on it
Old Nov 5, 2006 | 04:40 PM
zeeanswer's Avatar
zeeanswer
Shut this forum down. It's not needed. Actually, let's have all the forums closed. What's the point?
Old Nov 5, 2006 | 06:35 PM
Barzten1's Avatar
Barzten1
Poor guys asking for some input and he gets griefed. Thats what these forums are for aren't they? Wish I had these shocks but pricey.
Old Nov 5, 2006 | 06:42 PM
Eazzy's Avatar
Eazzy
Iz Bad ---I ran my mouth a little till I went out and disconnected mine and found that something is more than meets the eye. There are now 2 of us inquiring, One out of neccessity and me out of curiousity. Fock the dealer and maybe Fock Nismo for not sending a little paper work to help with the install.
Which I originally figured was just common sense.
>>>> Slapping Myself <<<<< for jumping to conclustions
Old Nov 5, 2006 | 07:07 PM
myZter's Avatar
myZter
PREMIER MEM.FTW
haha. where are all the people who installed it.
Old Nov 5, 2006 | 07:16 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
just checked the service manual.
in bl.pdf page 86 it shows that removal is to remove the stud ball on the trunk lid and then the bracket on the rear section off and install in reverse order. Does not say if the ball comes out.
gl with it, hope that helped.
Old Nov 5, 2006 | 07:24 PM
myZter's Avatar
myZter
PREMIER MEM.FTW
well taking unscrewing is all easy i did that but then the feakin lil ball thingy wont comeout. that part is like all scratched up. thats the part me and e***zzy is having a problem.
Old Nov 5, 2006 | 07:31 PM
zeeanswer's Avatar
zeeanswer
Originally Posted by myZter
well taking unscrewing is all easy i did that but then the feakin lil ball thingy wont comeout. that part is like all scratched up. thats the part me and e***zzzy is having a problem.
The kit should come with a new ball. I believe it is designed so that once you put the ball in it doesn't come out.
liqalu04
Jan 2, 2022 12:58 PM
3vilbunny
Jul 18, 2017 05:10 PM
