Help, my passenger side "door arm" is gone!
Old Nov 23, 2006 | 05:41 PM
tripndesi's Avatar
tripndesi
Default Help, my passenger side "door arm" is gone!
Guys, for some unknown reason, my handle on my passenger side door came off. I am including a picture so you can see. What are options other than glue? I Do not want to use that, what are the costs involved? Do i have to get a new passenger side panel for this?
2. Also my passenger side power window wont go up
3. I hear random clicks from the back when shifting the car from reverse into drive.
4. While opening the hood of my car it had a red and white sticker indicating it was equipped with remote start. Is this possible? How do I enable this?
My miles on my 2003 Car is at 87k.
Please let me know the top things to take advantage of while my car is still under warranty!
Please advise
Attached Thumbnails Help, my passenger side "door arm" is gone!-smalldriverside.jpg
Old Nov 23, 2006 | 06:18 PM
ZCARBANDIT's Avatar
ZCARBANDIT
1. I cant remember how they attach.
2. Alot of the earlier z's have window probs. Youll be paying for it now w/o the warranty.
3.Prob. the rear axle tsb. Which they coat the axle in new grease and replace the hardware.
4. Aftermarket remote starter. Be better off either getting another one or just not using it.
Unless you have something like a mastertech warranty you will be paying for the work. Unless you do it yourself. Which isn't the hardest in the world.
P.S Use the search button for the axle and the window stuff. It's littered everywhere on the site.
Old Nov 24, 2006 | 07:17 PM
350ZEnthusiast's Avatar
350ZEnthusiast
Pry off the aluminum cover and you will see two screws. If you can screw it back on, then great. If not, you might have scripped the holes where the screws go and will need to fix them.
Old Nov 28, 2006 | 08:28 AM
ericjackson's Avatar
ericjackson
it is broken, it is a $20 part from performance nissan or your local dealer. it goes on w/ screws on the top and bottom. as for you window motor, there is a thread somewhere on a fix. it worked for me.
btw, my handle has broken twice, if you need me to write directions, let me know. it is very simple
Old Nov 28, 2006 | 08:30 AM
ericjackson
http://www.trademotion.com/partlocat...03&catalogid=2
i assume it is black from the picture, this is all you will need, you can just pry off the alluminum peice and place it on the new grip handle
Old Nov 28, 2006 | 08:35 AM
ericjackson
https://my350z.com/forum/maintenance-and-repair/142013-window-motor-repair-replace-motor-brushes-3.html
check this page out. it fixed my pass window. for some it may just be a temp fix. but it is still a fix
Rev_Night
Nov 7, 2020 06:00 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
samansharif
Sep 25, 2015 12:31 PM
