Head light question
I have been looking at all these threads on painting the head light housing and I have yet to see one that is done like how I want it done. I have a 2004 Z with non-hid and I want my housing to look just like this http://www.mrzipps.com/ but I have 2004 head lights, will this make light output terrible? Has anyone done a full black out to the housing except the projector its self?
thanks
Jonathan
thanks
Jonathan
On the pre 06 lights, you will need to leave the reflectors on both sides of the projector. In the blinker area, if you go with the forward facing LEDs you wont need the reflector behind that. As for the high beam and parking lamps, below the projector, you can't black that our either.
Chris
Chris
Chris
Chris
why not...? im not trying to be a smart a$$...
The 06 headlights are "true projectors", not needing the side areas to reflect light. That's why I changed my headlights to th 06's then painted it.
here's another one for your reference:
All of those lights use the reflector to put more light forward.
For instance, if you black out the reflector for the high beam, it will no longer have any throw. It wont put any meaningful light in front of you.
Here is an experiment for you:
Take a mag light and compare the following. With the lens cap in place focused across a dark room and notice how bright focused area is.
Now unscrew the lens cap so you just have an exposed bulb. The bulb itself has not changed brightness but because it has no focus, it only cast a dim light around the whole room. Now cup your hand around half of the bulb allowing the other half to show on your same section of wall as you did before (your hand is acting like the black painted reflector), the open side will still cast that same dim light (you could also try this by painting your mag light reflector but I doubt you want to do that). Without focus, even the little parking lights are unable to do the job.
Another thing to think about would be this, lets say you painted your signal section black, now instead of an area of about 2x6" that spreads as it travels out, you only have about a 1x1" circle that pretty much stays a tiny point of light. Not many people will notice such a small spot flashing at them in the day time.
Chris
Chris
Originally Posted by Nitrouz
because you have a "reflector" headlight assembly. You need the chrome areas to "reflect".
Chris
Chris
this is going to be a project for sure.
Here are mine. 04's with the ENTIRE headlight blacked out. Even the outer projector housing. I could have left it silver and similar to what's posted above and save myself some work, but i wanted my car BLACK BLACK BLAAAAACK. It's true however, that your high beams will become next to useless doing it this way. Some people, like me, couldn't care less about high beams since i never use them anyway.
https://my350z.com/forum/questionable-posts/216192-fs-04-hid-blacked-out-headlights-100-a.html
Workshop12
Mar 23, 2020 01:45 PM
bcoffee20
Nov 19, 2015 06:39 PM
Vigman
Nov 17, 2015 04:34 AM
HoneyBadgerRy
Sep 21, 2015 03:25 PM
