Removing "350z" lettering question
Old Dec 28, 2006 | 07:03 AM
Ideapimp's Avatar
Ideapimp
Default Removing "350z" lettering question
Anyone out there a master at this type of thing? I know they're just basically stickers but is there some sort of trick to it?
Last time I pulled one of these off I took ice cubes and got the glue really cold then just snapped them off. I'm wondering if that's not the best for the paint though.
So, any help would be appreciated.
Old Dec 28, 2006 | 07:12 AM
jtabraham's Avatar
jtabraham
Getting the emblems off isn't too bad at all...they're stuck on with strong double sided tape.
I got them off, by heating the emblems up with a hairdryer, until they were hot to the touch (if you use a heat gun, you must be uber careful not to overheat the area). Some members also pour hot water on them instead of using the hairdryer.
After warming up the emblems, the adhesive becomes tacky. Take some fishing line or dental floss, and work through the tape back and forth, trying to get it under the adhesive. You'll be surprised at how easily it goes through.
One your done, you can get rid of the residue with some Goo-Gone or mild adhesive remover. I just rubber my finger over the residue until it "rolled" off of the paint.
Good Luck!
Old Dec 28, 2006 | 07:26 AM
ANXIOUZ's Avatar
ANXIOUZ
Hairdryer + dental floss did the trick for me. Then I just kept using the hairdryer + my finger to get off the residual glue.
And just to throw this out there....the center Nissan emblem will leave 2 holes if you try to remove it. The 350Z is just glued there so it's not a problem.
Old Dec 28, 2006 | 07:36 AM
06r33z's Avatar
06r33z
use a sticker scraper comes right off
Old Dec 28, 2006 | 07:51 AM
sam30540's Avatar
sam30540
I made an emblem remover out of an ice pick (i would not recommend this method). It worked for me but i was very careful and it stressed me the hell out while i was doing it.
Old Dec 28, 2006 | 07:53 AM
jtabraham's Avatar
jtabraham
i would be weary of using any type of pick or scraper in close proximity to your paint.
Dental Floss: Safe for gums and auto paint!
Old Dec 28, 2006 | 08:01 AM
sam30540's Avatar
sam30540
I will definately not use it again, I was in a hurry to get my fairlady emblem on and didn't have the proper tools or knowledge at the time...
Old Dec 28, 2006 | 10:25 AM
Ideapimp's Avatar
Ideapimp
Hairdryer + fishing line or dental floss = seems the way to go.
Another question for the gallery:
With the fairladyZ emblem, is there a standard measurement as to where placement should be? Should I leave the Z on from the 350Z emblem and just put the fairlady to the left of it? or should I remove it all and make some sort of measurement?
Old Dec 28, 2006 | 10:27 AM
JDMFairladyZ33's Avatar
JDMFairladyZ33
Fishing line or dental floss. Then you can clean the sticky stuff left behind with Goo Gone.
Old Dec 28, 2006 | 10:31 AM
sam30540's Avatar
sam30540
My emblam came with foam around it that lined it up with the side and bottom of the hatch
Old Dec 28, 2006 | 09:51 PM
mthreat's Avatar
mthreat
Hairdryer and dental floss worked great.
Then to get the remaining adhesive off of the car, WD-40 works great. If you're putting a new emblem on, be sure to wash all the WD-40 off first!
Old Dec 28, 2006 | 10:20 PM
WangZ808's Avatar
WangZ808
be really careful removing all the left over sticky tape ...i took my time with the emblems...then hurried the clean up job on the tape residue, and scratched my paint ;( should of used wd-40 never thought of that!
Old Dec 29, 2006 | 07:05 AM
ANXIOUZ's Avatar
ANXIOUZ
I think I still have my Fairlady emblem foam. I can probably measure it this weekend if anyone really needs it. Although without the foam in hand it could be tough to keep it straight.
I actually left a little bit of the 350z glue towards the bottom of the lettering. Then I applied the Fairlady...and then removed the 350z remnants. It was kinda tough to get between the letters but in the end it worked out great.
Old Dec 29, 2006 | 07:14 AM
SILVERBLACK_RL's Avatar
SILVERBLACK_RL
Can you use the same method for the Nissan burger on the hatch?
Old Dec 29, 2006 | 10:37 AM
Voboy's Avatar
Voboy
Hot water works too.
Old Dec 29, 2006 | 02:16 PM
sluggoZ's Avatar
sluggoZ
Yes. Coupes have 2 holes exposed but the Roadster's do not!
Old Dec 29, 2006 | 02:25 PM
97supratt's Avatar
97supratt
So we know that using a hair dryer and fishing line and dental floss work but the real question is "What flavor do we use?". hahah Sweet cinnamon or miracle mile mint.
Old Mar 5, 2007 | 08:50 PM
dayz's Avatar
dayz
I used a plastic fork on the front burger. See "front emblem & plastic fork"
Old Mar 6, 2007 | 02:16 AM
fucy626's Avatar
fucy626
Goo Gone!
Old Mar 6, 2007 | 03:51 AM
MiniRide's Avatar
MiniRide
So I can take off my center nissan on my Roadster and there are no holes?
