Rear hatch too heavy w/ new wing?
Old Jan 10, 2007 | 08:44 PM
d!abolic's Avatar
d!abolic
Default Rear hatch too heavy w/ new wing?
I had the INGS LX wing installed the the hatch is too damn heavy now. Believe it or not, helf the time it ends up falling on my head when I'm digging around in the drunk. How the hell do I fix this? Is there a way to tweak the supports so that they require more pressure to be applied before the hatch goes down?
Old Jan 10, 2007 | 08:52 PM
WalkerT's Avatar
WalkerT
Professional
nissan sells stronger shocks for the nismo wing look on mynismo.com
Old Jan 10, 2007 | 08:54 PM
myZter's Avatar
myZter
PREMIER MEM.FTW
you need more then stronger shocks u also need other parts for it.
Old Jan 10, 2007 | 09:08 PM
WalkerT's Avatar
WalkerT
Professional
I thought it came as a kit. shocks and mounting hardware.
Old Jan 10, 2007 | 09:17 PM
myZter's Avatar
myZter
PREMIER MEM.FTW
i dont think so why dont u ask
Old Jan 11, 2007 | 08:46 AM
steveiZdaman's Avatar
steveiZdaman
yea my veilside weighs it right down also
Old Jan 11, 2007 | 11:23 AM
o's Avatar
o
http://www.thezstore.com/store/merch...ry_Code=BSC09I
We sell the left and right for 99 each.
One is probably strong enough, But I would suggest the set.
Michael
www.350zsource.com
Old Jan 11, 2007 | 12:54 PM
MustGoFastR's Avatar
MustGoFastR
There was another recommendation a while back about a place you could send your stock struts to and they would re-build them to be stronger for way less $$$ than the upgraded OEM struts cost. Search around.
Old Jan 11, 2007 | 12:59 PM
ldawg32's Avatar
ldawg32
they have aftermarket ones to hold the weight try search on it
Old Jan 11, 2007 | 01:00 PM
ldawg32's Avatar
ldawg32
hi
Old Jan 11, 2007 | 01:01 PM
ldawg32's Avatar
ldawg32
hope these help. i have the same prob and am about to order these
Old Jan 11, 2007 | 01:18 PM
jtabraham's Avatar
jtabraham
I have a Nismo wing and had the same problem as you. I worked with a supplier I deal with at work and was able to get some heavier duty struts to hold up my hatch with the wing installed.
I have some business trips, but will most likely become a site vendor next month when I get back. PM me if you are interested, and I can hold a group buy when I become a vendor.
Oh and to answer your original question, the OEM struts don't have any adjustment. They are not rated to hold the weight of a hatch and a spoiler, so the only solution is to get new struts, or prop your hatch open.
Old Jan 11, 2007 | 08:26 PM
d!abolic's Avatar
d!abolic
Did you delete the post?
Old Jan 12, 2007 | 02:46 AM
Mapleleaf's Avatar
Mapleleaf
Try this http://www.strutwise.com/index.php they are in B.C , send them your rear shocks and they will rebuild them for under $100 Canadian. Phone and ask for Frank
Old Jan 13, 2007 | 01:26 PM
Z1truth's Avatar
Z1truth
I just installed my struts I bought from jtabraham and they work great! Or should I say 1 works great! I put the VS spoiler on and had the same prob as did d!abolic. Damn that hurt when it hit my head! So I read a post by jtabraham and PM'd him and WaaaLaaa he sent them to me ASAP and I'm good! And at a very reasonable price too!
I only needed one side to help it stay up like OEM, so I'm keeping the other one if this gets weak down the road.
One suggestion tho......buy the new upper and lower ball joints and make it easy on yourself! The dremel method is time consuming, and when you try to remove the upper ball joint you will most likely strip the bolt part with the open end wrench! Much easier to cut it off with a dremel at the ball shank portion and just bolt in a new upper ball end. Just my .02 cents!
Thanks jtabraham.......appreciated!
Old Jan 13, 2007 | 04:07 PM
Agentman03's Avatar
Agentman03
Same Problem When I put on a Nismo Spoiler .. When Working out of Trunk I have a small Plastic clamp to put around the Strut.. New Struts are Real Price'y ..Thought about maching a small spring loaded ball or snapring type setup on the stock strut ..probably better to just pay the freight and buy a heavy dudy rear hatch strut ??
Old Jan 13, 2007 | 07:24 PM
davidf's Avatar
davidf
Remove the inner hatch panel, remove weight attached to inner hatch, delete wiper motor, reinstall panel, you should be alright.
Old Jan 14, 2007 | 10:43 AM
Jes-Z's Avatar
Jes-Z
I have a nismo Spolier and about 3 layers of dyno mat on the trunk. Is there any industrial strength Shock? If i dropped the trunk on my head I would probably end up in the hospital. It's really heavy.
Old Jan 14, 2007 | 11:47 AM
jtabraham's Avatar
jtabraham
Originally, when I chose stronger hatch struts after getting my nismo spoiler installed, I chose a set that was a little too strong. I still have that set sitting around, so PM me if you are interested. With the added weight of dynomat on top of your spoiler, these might work perfect for you though.
Jason
Old Feb 21, 2007 | 06:18 PM
toykilla's Avatar
toykilla
http://dinky-link.com/?hV1fSCd3
