Removing Stock Embelms?
Old May 15, 2007 | 05:33 PM
xNeo's Avatar
xNeo
I just wanted to thank everyone for their help and input.
The first thing I did when I got home was I yelled out "Tony! I need a blow dryer, goo gone and dental floss." He immediately replied with: "Who do you think you are Macgyver?"
After the laugh we went down to the garage and followed the steps as described and it took us no longer than 10 minutes to get the entire thing off including all of the adhesive. The only touch I added was while I was holding the blow dryer I had him pour goo gone just above the letter. After the letter came off, I rubbed the adhesive with a microfiber towel and it immediately came off.
Putting on the Fairlady Z emblem was as described above, couldn't be any easier. Here are some pictures:
Attached Thumbnails Removing Stock Embelms?-before.jpg   Removing Stock Embelms?-during.jpg   Removing Stock Embelms?-after.jpg   Removing Stock Embelms?-after2.jpg
Old May 15, 2007 | 06:16 PM
blknjz's Avatar
blknjz
afre there holes below the side emblems?
Old May 16, 2007 | 05:38 AM
sixsigmalarry's Avatar
sixsigmalarry
Smile Nope...
There are no alignment holes for the "350Z" emblem on the side. The only holes on the rear hatch are from the center Nissan emblem. From what I've read, the roadsters do not have any holes back there.
Hope that helps!
Old May 16, 2007 | 05:47 AM
6SPD Z33's Avatar
6SPD Z33
Originally Posted by sixsigmalarry
About how far away from the paint/emblem should I keep the hair dryer? -
I had my ex gf's hairdryer (knew she was good for something...WHAA HAA HAA!) about 2 to 3 inches from the emblem until it was hot to the touch.
Is it possible to damage the paint with the hair dryer or floss? -
No and no, to my knowledge and from the posts I read. I used fishing line to seperate the glue backing from the emblem. If you want to someday reuse the emblems, make sure they don't fly off and hit the concrete.
How long until it's gooey and how can I tell? -
If you mean from the hairdryer, well, the emblem will wiggle more. If you mean from the Goo Gone step, you'll know from touch.
Should I focus on one letter/number at a time or the entire string? -
I'd do one letter at a time....
Some lessons learned-
After you seperate the emblem w/the glue backing, shoot it with Goo Gone and let it soak in the glue backing, then start to peal it away. It was a PITA! Spray and peal (repeat....over and over!)
I ended up with some minor scratches, but that didn't bother me since I was going to cover it ALL up with another Z side emblem (replacing all my GOLD emblem with OEM finished ones).
I read that someone took a valve stem piece and fitted it to a drill to take off the glue backing. I'm still doing research on this method, since I'm also taking off my 350Z rear deck lid emblem off and NOT replacing it with an emblem. So, I definitely do not want any scratches.
I'll keep you posted!
I saw your sig... "the new kid?" was your 350Z the "bling mobile?"
Old May 31, 2007 | 07:57 PM
B-MAC's Avatar
B-MAC
Question Fairlady Emblem
What is the Fairlady emblem? Pardon the ignorance.
Old May 31, 2007 | 09:42 PM
nzpv03's Avatar
nzpv03
for real? dude scroll up!
Old Jun 1, 2007 | 05:45 AM
B-MAC's Avatar
B-MAC
Yes, I finally found/see it. The graphics loading from this site is not smooth.
What is the deal with Fairlady. Again, I am a newbie to the program. The garage reeks of new Z.
Old Jun 1, 2007 | 05:54 AM
Ghost 350z's Avatar
Ghost 350z
The 350z is call Fairlady Z in Japan
Old Jun 1, 2007 | 06:53 AM
b00stedjustin's Avatar
b00stedjustin
you don't need gooo gone. Use a wet rag and a hair dryer and push the remaining adheasive off in extremely small quick strokes pushing in a constant direction. I removed the infiniti lettering and G35 badges this way. It was really easy, and just took a little time and patience.
Old Jun 18, 2007 | 07:44 PM
10sec_CRX's Avatar
10sec_CRX
are there any measurements for where the fairladyZ goes or did you just slap it on there...
Old Jun 19, 2007 | 07:04 AM
MarkY's Avatar
MarkY
It should come with a foam template.
Old Jun 19, 2007 | 10:11 PM
10sec_CRX's Avatar
10sec_CRX
i just got it today i see what you mean about the foam thing. Thanks
Old Sep 21, 2007 | 05:59 AM
PFI350Z's Avatar
PFI350Z
Ok. I got that the 350z in the back has no holes and the nissan in the front has no holes. the nissan in the back has holes. How bout the Z in a circle on both sides of the car? holes or no?
Old Sep 21, 2007 | 06:28 AM
Shift_Z33's Avatar
Shift_Z33
^ Yes, those have holes behind them
Old Dec 13, 2007 | 07:06 PM
t1m1t's Avatar
t1m1t
hey guys, i just debadged the 350 Z badge with dryer and floss like everyone was saying earlier
my problem is, i can still see 350 Z imprinted on the hatch... it's like the sun baked the image on there...
question is, should i just go ahead with the fairlady badge, or should i do something about the faint 350Z image?
thanx in advance
Old Dec 13, 2007 | 07:37 PM
gruntysmasher's Avatar
gruntysmasher
Go to Autozone, get some Turtle Wax rubbing compound or somesuch, rub it in where the markings are, and it should remove it. Afterwards, WAX the area (after cleaning and claybarring, of course), or better yet, just wash your whole car the right way.
The rubbing compound should remove the fading/garbage in your paint.
Old Dec 13, 2007 | 07:38 PM
gruntysmasher
As for emblems, debadging FTW. Take the 350Z emblem off (you've already done this) and drive around, look at it, ask opinions, and then if you still want Fairlady, then add it.
thanx in advance
Old Jan 11, 2008 | 04:43 AM
  #38
MDaniel22's Avatar
MDaniel22
Did anyone end up changing the fender emblems? I replaced my front and rear ones no problem. Should I use the same hairdryer + floss for the fender ones?
Old Jan 12, 2008 | 07:27 AM
  #39
Chaser720's Avatar
Chaser720
Lemoned Z
IM planning on taking mine off today and sanding them down and repainting.
Just still researching on paint and finish.
And the "350Z" came off without floss or hair dryer so im going to see what i can do.
Old Jan 12, 2008 | 07:52 AM
  #40
MDaniel22's Avatar
MDaniel22
Let me know how it goes for you. I have the black pearl emblems for the sides, but it seems as if the fender ones are on there a little better than the rest were.
