takata harnesses
Old Jan 19, 2007 | 02:31 AM
workseuge's Avatar
workseuge
Default takata harnesses
has anybody ran the takata long harnesses in their Z....i've seen the short harnesses with the harness bar but nobody with the long without the harness bar...i was just wondering if anybody has done this cuz my cuzzin gave me a deal on harnesses that i couldn't pass up but they are the long ones and i dont know what to do...any help would be greatly appreciated!
Old Jan 20, 2007 | 05:27 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
they will work just fine
Old Jan 20, 2007 | 11:21 PM
workseuge's Avatar
workseuge
Default seat belts
with or without the harness bar?
Old Jan 21, 2007 | 05:17 AM
Z1 Performance
Former Sponsor
you can't use a harness without a harness bar or rollcage
Old Jun 24, 2008 | 09:35 AM
PowaHouseAlex's Avatar
PowaHouseAlex
Why woulnt they?>
you have to find were you can attach the EYE BOLTS
Old Jun 24, 2008 | 09:40 AM
Z04's Avatar
Z04
Originally Posted by PowaHouseAlex
Why woulnt they?>
um, what part of that did you not understand? seems pretty clear to me that you can not use a harness without a harness bar or a roll cage. that is what the harness is designed for.
Old Jun 24, 2008 | 09:46 AM
z-u-later's Avatar
z-u-later
If you don't have a harness bar or a roll bar, pull the harnesses all the way back, wrap them around the the rear strut bar and tie a knot.
Old Jun 24, 2008 | 09:48 AM
Z1 Performance
Former Sponsor
or stretch them all the way back to the hatch, and close the hatch on top of them
Old Jun 24, 2008 | 09:51 AM
PowaHouseAlex
And what a stupid statement is that
There are diffrent ways to set up a harness
1.use eye bolts
2.use roll bar,roll cage
Old Jun 24, 2008 | 10:22 AM
chris'smax's Avatar
chris'smax
or If you want to do it right you could just buy the cusco roll cage and takata harnesses (thats what i did). Just do it right my man so you don't squash your melon
Old Jun 24, 2008 | 10:29 AM
redlude97's Avatar
redlude97
Old Jun 24, 2008 | 10:34 AM
SpoilsofWar's Avatar
SpoilsofWar
omg this is a joke right?!? Please say yes
Old Jun 24, 2008 | 10:54 AM
PowaHouseAlex
Sounds good lol
Old Jun 24, 2008 | 11:33 AM
Jim@Showstoppers's Avatar
Jim@Showstoppers
lol...that's ghetto.
Old Jun 24, 2008 | 11:57 AM
Z04's Avatar
Z04
1.use eye bolts
stupid? all i did was repeat what Z1 said, you need the harness bar or roll cage for the harness to work. no sheisse you have to use the eye bolts in the floor, that was not the discussion. so next time you go and make a post saying you "just got to find the eyebolts", be sure you know what the topic of the thread actually is first.
and so you know there is only one way to install a harness bar, and that is the right way.
Old Jun 24, 2008 | 01:14 PM
ZTEALTH's Avatar
ZTEALTH
hahahahaha! or make a hangmans nuse and put it around the passengers neck!
a couple years ago i restored an old bronco, someone actually built a rollcage out of pvc pipe covered in rollbar padding! just when you think you've heard it all...
Old Jun 24, 2008 | 06:34 PM
chris'smax's Avatar
chris'smax
Originally Posted by redlude97
If your saying the cusco cage isn't safe then you havent seen it in person. The bars are made of chromoly (ie tough ****). The joints are extremely thick and each bolt is about 1/2 inch in diameter. Now i am not saying this is as strong as a welded cage, but it is by no means a slouch. I plan on having the cage welded anyways so it really doesn't matter
Old Jun 24, 2008 | 08:31 PM
SpoilsofWar
Not arguing that its better then nothing, but the Cusco cage is basically a show piece. I know none of the tracks around me will accept a bolt in chromoly cage, its either DOM or go slow.
If you are serious enough to need a cage, then you should know that you need welded DOM. If its just for a show car or a place to mount harnesses on a street car (why you'd need harnesses on a street car I dont know, but regardless) then the cusco will suffice.
Old Jun 24, 2008 | 08:52 PM
Kwame's Avatar
Kwame
FWIW if your looking for a bolt-in cage/rollbar to strap your harnesses to, the Cusco is definitely not the most ideal choice as it does not have a built in harness bar. If you are not planning on running harnesses then it will be perfectly fine for a street/show car.
If running a harness(es) is part of your plan than the Kirk or Autopower Rollbars might be a better alternative.
Old Jun 24, 2008 | 08:54 PM
SpoilsofWar
I thought it had an optional harness bar piece?
If it doesn't, aside from putting it in a show car, I can't see any purpose for it at all.
