Aftermarket steering wheel problems!!!
Old Jan 31, 2007 | 04:10 PM
05 NISMO's Avatar
05 NISMO
Default Aftermarket steering wheel problems!!!
Ok, I just got my new momo jet steering wheel and also momo hub but when I remove the orignal wheel I notices that there are two color wires (yellow and red), Im thinking that the yellow wire are for the airbag and the red are for the honk, then I when on installing the fuse that came with the momo hub to the yellow wire, and I notices that the airbag lights came on, did I do something wrong here? and also I took it out for a ride and the momo wheel seem very stiff to turn... did i installed wrong?
Old Jan 31, 2007 | 04:23 PM
davidf's Avatar
davidf
What you installed should have been a 2ohm or greater resistor, not a fuse. As far as stiff turning, sounds like something rubbing.
Old Jan 31, 2007 | 04:29 PM
05 NISMO's Avatar
05 NISMO
well the one that came with the momo hub had it label 2 on the fuse mark, isnt that 2ohm? also i didnt see anything rubbing... should it feel like my stock wheel on turning?
Old Jan 31, 2007 | 05:23 PM
Chebosto's Avatar
Chebosto
i dont think you can fool the steering wheel airbag. only the seats/curtains.
Old Jan 31, 2007 | 06:02 PM
TayTaythatsme04's Avatar
TayTaythatsme04
if you can I would like to know also
T
Old Jan 31, 2007 | 06:06 PM
TruBluZ's Avatar
TruBluZ
I don't have the light on mine. You need 2 resistors.
Old Jan 31, 2007 | 06:09 PM
TayTaythatsme04
more info ???
T
Old Jan 31, 2007 | 06:20 PM
TruBluZ's Avatar
TruBluZ
Truthfully, I can't remember why you need 2. I would have to remove my steering wheel to see what I did. When I bought my wheel, hub and quick release, it came with 2 resistors. When you connect both, you get no lights.
Old Jan 31, 2007 | 06:34 PM
TayTaythatsme04
what kind of wheel,hub, and quick release do you have ?
Any pics ?
T
Old Jan 31, 2007 | 06:38 PM
Chebosto's Avatar
Chebosto
Yea. +1 if you can take off the hub, and measure the resistance, that would be great..
Old Jan 31, 2007 | 07:00 PM
TruBluZ's Avatar
TruBluZ
I have a Nardi wheel with a Works Bell hub and quick release. I'll check on the resistors tomorrow and let you guys know something. I don't have any good pictures of the hub and wheel
Old Jan 31, 2007 | 07:02 PM
05 NISMO's Avatar
05 NISMO
is there a special way to mount the hub? because ive tried every angel and it seem that my wheel are still stiff, should it be that stiff? its so stiff that the power steering doesnt work (I could just bust donut without having to hold onto the wheel... thats how stiff it is). HELP!!!
Old Jan 31, 2007 | 07:04 PM
TruBluZ's Avatar
TruBluZ
It should not be stiff at all. It should feel like stock. Can you take a picture of the hub installed without the steering wheel?
Old Jan 31, 2007 | 07:17 PM
TayTaythatsme04
I just got a sparco wheel, with the 6 hole pattern, any suggestions on hub and quick release ?
T
Old Jan 31, 2007 | 09:14 PM
05 NISMO's Avatar
05 NISMO
Here are some of the pictures i just snapped, also which color wire is for the airbag?
Old Feb 1, 2007 | 07:36 AM
Chebosto's Avatar
Chebosto
i think both yellow and red clips are..
after lookin at the service manual, the driver side airbag has 4 connections (as compared to the side seat airbag which only has two.) then goes to three from the spiral conenctor. did you put the resistor between both of them? i.e. connect the red with the yellow with a resistor in the middle?
i think you'll need two resistors for each connector..? just whatever you do. DO NOT PUT MULTIMETER TO YOUR AIRBAG to try to measure the resistance.. the voltage inside might set it off..
Attached Thumbnails Aftermarket steering wheel problems!!!-airbag.jpg   Aftermarket steering wheel problems!!!-airbag2.jpg
Old Feb 1, 2007 | 07:50 AM
THE TECH's Avatar
THE TECH
Nismo makes a wire harness to aleviate this. I believe you can find it on www.mynismo.com
Old Feb 1, 2007 | 08:37 AM
pesci's Avatar
pesci
If you have removed or are thinking about removing your stock wheel, give these people a call. They sell the kit for our cars that makes the system think the air bag is still in. They have EXCELLENT customer service and the guy is cool. I used them and had to call him at his house to get info and the guy was like no problem, lets talk. So I would highly recommend them, also I did an DIY for the wheel removal. The mom hub does not fit all that great, the company NRG makes a hub that fits perfect..
http://www.airbagonoff.com/
Old Feb 1, 2007 | 09:11 AM
THE TECH's Avatar
THE TECH
^^Good info, nice find.
Old Feb 1, 2007 | 09:40 AM
TruBluZ's Avatar
TruBluZ
After seeing the pictures, I now remember what I did. You will need a seperate resistor for each connector. When I get home, I will take the hub off and snap some pictures, if needed. In total only 2 resistors are needed.
