How to install front Lip??
Old Feb 7, 2007 | 03:36 PM
first350's Avatar
first350
Red face How to install front Lip??
**I've searched this all Z forums and the general internet**
I just got a VS1 lip and am trying to figure out how to install it ...The bottom portion that will be flush with the underbody) extends past the mounting bolts that holds the underbody plastic peice - Do I need to trim the VS1 lip or do I use the OE bolts to secure the bottom of the lip?
I've read that others just use 3M double-sided tape to secure the top of the lip to the bumper...I'm planning to do the same.
Any pics of the process (or just what it looks like underneath) would be greatly appreicated.
-Peter
Old Feb 7, 2007 | 06:47 PM
sokudo9l6's Avatar
sokudo9l6
VS1 as in veilside ver.1? I have a real veilside lip and everything matched up. The fittment was really tight tho... I re-used the OEM bolts to secure the bottom of the lip to the underbody plastic piece. the lip also came with double-sided tape already on it.
Old Feb 7, 2007 | 07:08 PM
THE TECH's Avatar
THE TECH
Hmm...there shouldn't need to be much explanation for this one.
Old Feb 7, 2007 | 07:11 PM
AroundMyHorn's Avatar
AroundMyHorn
-Peter
where did you buy it from?
Old Feb 7, 2007 | 08:27 PM
first350's Avatar
first350
*it was a knock-off from JDMZ33.
I just wasn't sure if I was supposed to use the OEM bolts from the plastic under tray or not. Changing out engine parts (headers, exhaust, plenum,...) is what I've always done...but exterior stuff always takes me 4X longer - just not my thing!
thanks,
Peter
Old Feb 12, 2007 | 06:24 PM
first350's Avatar
first350
okay, so I finnaly had a chance to test fit the lip and it looks good, but there's a small vertical lip just under the OE bumper that's in the way for me to use the under body panel bolts...here's the pic of what I'm talking about:
am I supposed to just cut this off?
thanks,
Peter
Old Feb 12, 2007 | 09:18 PM
350redline's Avatar
350redline
thats the, "oh siht i think i just scratched the hell out of my bumper" plastic lip.
Old Feb 12, 2007 | 09:23 PM
ElDiablo82's Avatar
ElDiablo82
@first350
I have the same lip and I will have to install it soon. It would be great if you could send me some pics or hints or whatever. Just your impressions. Thanks in advance
Old Feb 12, 2007 | 11:45 PM
sokudo9l6's Avatar
sokudo9l6
thanks,
Peter
Peter...don't worry about that piece. It doesn't get in the way of the install. Just apply double-sided tape to the back of the veilside lip (the part were it meets the center part of the bumper) then using the 4 bolts (2 on each side) found under the car and bolt it on. You'll see how easy it is once you look under the car.
Derek
Old Feb 12, 2007 | 11:50 PM
sokudo9l6's Avatar
sokudo9l6
oh yeah...i forgot to add. I don't know how the fittment is on the replica version but my real one was a REALLY TIGHT fit. It would be easier if you had some help holding the lip in place while you bolt it on. It took me a lot longer than expected trying to install it by myself.
Old Mar 11, 2008 | 04:31 PM
DaytonaRoadster's Avatar
DaytonaRoadster
i'm having a similar problem from a V1 lip i bought from Intense power, the region below the opening where the opening for the radiator is, the lip seems like its to long, is it supposted to flex up? I havent losened the bolts yet, i'm just test fitting it
Old Mar 12, 2008 | 12:41 PM
RedBullRR's Avatar
RedBullRR
Looking for more info on this install myself. Just received the VS1 lip from JDMZ33 as well.
kyin
Oct 15, 2015 05:54 AM
samansharif
Sep 25, 2015 12:31 PM
