Need some input about this product
Old Feb 13, 2007 | 03:24 AM
ebichuz's Avatar
ebichuz
Default Need some input about this product
I was wondering how hard it is to cut a hole in the bumper with a exacto knife and whether or not this is a good idea...Kinda scary to cut a hole in my 1 month olf 06 ...http://cgi.ebay.com/ebaymotors/NISSA...QQcmdZViewItem
Old Feb 13, 2007 | 04:44 AM
davidf's Avatar
davidf
If you have acsess to a dremal that works better.
Old Feb 13, 2007 | 05:56 AM
THE TECH's Avatar
THE TECH
+1 on the dremel.
Old Feb 13, 2007 | 07:14 AM
zdero's Avatar
zdero
It's really not that bad of an install. The idea of cutting a hole in your bumper is a little scary at first, but if you take your time you will be fine. A dremel works nice. If you don't have you can actually just use a sharp pocket knife.
Old Feb 13, 2007 | 07:38 AM
ObiRedKenobi's Avatar
ObiRedKenobi
Or you could use it as an excuse to go buy a dremel if you don't already have one
Old Feb 13, 2007 | 07:44 AM
mjcos77's Avatar
mjcos77
If you go with the exacto knife, heat it up in between cuts, a simple lighter works. It makes it go much easier.
Old Feb 13, 2007 | 09:53 AM
MustGoFastR's Avatar
MustGoFastR
A sharp utility knife works like a charm. It really is a simple DIY install.
Old Feb 13, 2007 | 10:15 AM
azula's Avatar
azula
just make sure u sketch where ur cutting first...
Old Feb 13, 2007 | 10:28 AM
MustGoFastR
Yeah, get the template lined up just right, then use a dry erase marker to outline the hole to be cut. Then it's an easy cut. Once the bumper hole is cut, you'll need to dig out a little of the foam bumper support behind it so the duct will fit in nice and flush, then just use self tapping screws or rivets to attach it.
Old Feb 13, 2007 | 10:34 AM
robbycolli's Avatar
robbycolli
Is this the unit to buy, or is there a better one on the market?
Old Feb 13, 2007 | 10:44 AM
MustGoFastR
Ebay ones are ok for the price, but they won't be perfect. Evo-R makes a nice one, and then there's of course the authentic Varis duct, which all others copied.
Old Feb 13, 2007 | 11:25 AM
robbycolli's Avatar
robbycolli
Thanks!
Old Feb 13, 2007 | 12:42 PM
ebichuz's Avatar
ebichuz
I was wondering also what kind of screws wont have a rust problem..and is it neccesary to use a bolt? Self tap good enough?
Old Feb 13, 2007 | 12:50 PM
MustGoFastR
Most of them come with self tapping screws. Rivets are better for security purposes, but if you're going to use screws and it doesn't come with them, just get brass screws and paint the heads black.
Old Feb 13, 2007 | 04:34 PM
03TEZ's Avatar
03TEZ
you do have to take the front bumper off to install this. i was looking at these as well.
Old Feb 13, 2007 | 05:12 PM
ebichuz's Avatar
ebichuz
why would you need to take the bumper off...I took a look today and it doesnt seem to get in the way of anything
Old Feb 13, 2007 | 05:25 PM
jetspank's Avatar
jetspank
I wondered about that too.
I recently got the Evo-R duct but it's been too cold to put it on so I've just been planning the install. When I got the duct I assumed I'd have to take my bumper off (like I did when I put on smoked side markers), but when I looked at where the duct was supposed to go (based on the template) it seemed like I could just cut the bumper in place.
Is this true?
Old Feb 13, 2007 | 05:27 PM
kh_08's Avatar
kh_08
hmmm......made me think of how it would look on the new '07 to have two of them b/c of the dual intakes......
Old Feb 13, 2007 | 06:03 PM
jetspank's Avatar
jetspank
Prolly look pretty amazing.
Old Feb 13, 2007 | 06:07 PM
MustGoFastR
You do not have to remove the bumper.
The duct is angled, so provided the pass side intake has a fresh air pass-through in the radiator core support like the dr. side, they would have to make a reverse angled duct to be compatible with that side of the car.
sales@czp
Sep 23, 2019 03:30 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
