Storage organizer $12 !!!!!!
Old Apr 4, 2003 | 09:01 PM
ZISBAK's Avatar
ZISBAK
Default Storage organizer $12 !!!!!!
Find this Trunk Storage at walmart!!! only $12!!!
Better than the cargo net from the OEM! The only problem is that had to used tape to make the pole a little shorter to make the storage to fit in the back!!! Beats spending $40+ for a cargo net or something like that, and it is conseal when the trunk hood is close. what do y'all think?
Old Apr 4, 2003 | 09:02 PM
ZISBAK's Avatar
ZISBAK
here is another view from the inside
Old Apr 4, 2003 | 10:26 PM
rodH's Avatar
rodH
does it fit snug, or move around?? (is there something that you did so it doesn't scrath the inside of the car??)
Old Apr 5, 2003 | 03:09 AM
kitkos's Avatar
kitkos
It has velcro on the stand to hold it in place.
I have this in my Yukon. Hadn't thought about the Z. Good idea shift_z. I think I'll test fit mine today.
Old Apr 5, 2003 | 06:50 AM
ZISBAK's Avatar
ZISBAK
you know, I haven't even thought about the velcro I've driven around for couple days now, and it has not moved around even without the velcro or anything. and It fit pretty snug, as far for scratching the inside of the car. If you notice anything might scratch, you could always get some more velcro tape and use the soft side and stick on all corners that you think might scratch
Old Apr 5, 2003 | 10:53 AM
ZISBAK's Avatar
ZISBAK
Thanks VQracer!!! Here is another picture of the minor modication that i had to do. Black electrical tape to make the pole a little shorter, since the last click won't fit. and some Velcro to avoid any scratchs on the car. Hope this would benifit a lot of Z members!
btw, they should start a section on " little mod would get you far, or little mods for cheap!"
Old Apr 5, 2003 | 05:58 PM
TonyZXT's Avatar
TonyZXT
Does it fold away pretty small if you need that room for something else on occasion?
Old Apr 5, 2003 | 07:45 PM
ZISBAK's Avatar
ZISBAK
yes, you could detach the poles from the side holder and lay everything flat if you need space. because they are not glue or anything like that. It's how ever you want to set it up.
Old Apr 6, 2003 | 05:00 AM
kitkos's Avatar
kitkos
It's designed to allow for extra space when the cargo net is not needed.
The front pole is adjustable so you can move it to a slot on top of the rig thus allowing more space.
SpartanZ32
Oct 22, 2015 09:36 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
c350z
Aug 14, 2002 09:48 AM
zmain
Jun 17, 2002 03:27 AM
