Help w/ Greddy sides
Old Feb 17, 2007 | 08:14 AM
yoichi's Avatar
yoichi
Default Help w/ Greddy sides
Hey guys, just wanted to know what size screws/rivets are used to secure the side skirt from the inside of the car when you open the door.
thanx
Old Feb 18, 2007 | 02:34 AM
sluggoZ's Avatar
sluggoZ
thanx
The rivets that came with the Greddy sides were too small so I had to remove the white grommets from the body...I bought a pkg of Dorman 5/16" /7,93mm part#799-100 at Auto Zone. You would need to loosen up the kick plate when installing the greddy sides & I also jacked the car up on one side & blocked. To remove the kickplate, you first have to remove the plastic pin toward the back & carefully lift upward. If you do break the pop rivets, install with velcro strips to re-stick back down. I would suggest to have a buddy help ya with the side skirt.
Old Feb 19, 2007 | 06:50 AM
yoichi's Avatar
yoichi
thanks alot
Old Feb 19, 2007 | 06:57 AM
nothingremains's Avatar
nothingremains
i had this same problem and still have never put mine on
Old Mar 23, 2007 | 04:14 AM
nothingremains
i couldnt find the dorman ones...i need to know what to do asap
Old Mar 23, 2007 | 05:37 AM
sluggoZ's Avatar
sluggoZ
PM sent....sluggoZ to the rescue!!!
Old Mar 23, 2007 | 07:21 AM
nothingremains
thanks a lot man
sales@czp
Sep 23, 2019 03:30 PM
samansharif
Sep 25, 2015 12:31 PM
