V.2 Spoiler question
I was wondering if the V.2 spoiler will cover the holes if you already have a v.1 spoiler installed.i want to know before i buy one, hate to waste the money if the v.2 wont cover the holes from the v.1.
Guest
Posts: n/a
Originally Posted by Z1 Performance
no it won't
i was curious about that aswell. i know the JDM replica or carbon versions usually go on using the 2 holes from the oem lip and 2 more. angled out and up maybe 3 or so inches
will the V2 still not cover this method?
i know it wont cover the USDM nismo wing because that template requires extra holes up higher on the hatch and the V2's base doesnt extend that far up
no, as mentioned, The Type E that we sell (through Evo R) it won't cover the holes of the V1. The genuine one is technically not in production anymore, though there are a few lone ones floating around, but it's the same situation as I recall
The USDM rear V1 spoiler actually does use OE mounting holes now as I recall -the original version did not
Well the V2 also uses the stock mounting points, but it also has two more towards the sides.
The V1 uses the stock mounting points, but then two more towards the top, which are alittle too far up for the V2 to cover up. It is about a 1 inch difference from the two.
I had the USDM Nismo V1 wing, and changed it to the V2 wing recently, and ended up with a higher bill because of this.
