aftermarket shift lights
Old Mar 7, 2007 | 05:56 PM
Chad68's Avatar
Chad68
Default aftermarket shift lights
When I get my stock tach noise figured out, I really want to install a aftermarket shift light that I can actually see, instead of the tiny single itty bitty factory LED shift light.
I'm asuming they install much like a tach and require a tach signal from a wire. Anybody have a pic of where a good signal wire would be to use? All I have been able to get is written descriptions of where one might find a wire to tap in to.
Old Mar 7, 2007 | 08:17 PM
Chebosto's Avatar
Chebosto
we have a CAN based car electronics system.. there isnt a tach signal, per say (i.e. RPM signal off the ecu, there are actually 6 injector pulse signals that actually go to the back of the speedo/rpm cluster)
what you can do is get a signal converter that takes the injector pulse signal from one and then do a 'single' cylinder operation... thats what i had to do for the Defi heads up display to get that to read rpm correctly and display the shift light.
i think someone else got to tap into the stock shift light inside the gauge cluster too... but it was a couple years ago. i dont remember who it was...
Old Mar 8, 2007 | 08:21 AM
james840a's Avatar
james840a
I have a Raptor Shift light in my car.
Here is a Link on the topic.
https://my350z.com/forum/audio-and-video/188319-raptor-shift-light-install-write-up.html
Old Mar 8, 2007 | 03:47 PM
Chad68's Avatar
Chad68
https://my350z.com/forum/showthread.php?t=188319
I actually found that link yesterday after I asked. Did it go smooth? Was the #23 wire the correct color and location?
Who did you order your Raptor from?
Uriyo_
Sep 8, 2021 08:46 AM
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
SharX59
Sep 27, 2015 09:23 AM
