Anybody remove a non-Homelink rearview mirror (base Z)?
Old Mar 15, 2007 | 03:48 PM
DavesZ#3's Avatar
DavesZ#3
Question Anybody remove a non-Homelink rearview mirror (base Z)?
The homelink mirror have a small set-screw that hold the base to the mount stuck to the windshield.
The non-homelink mirror apparently snaps onto the mount and doesn't have the set-screw to hold it. There is a small hole in the base where I assume you'd stick a screwdriver or some other implement to pop the base loose from the mount.
I don't want to break the mount loose from the windshield and I don't want to break the base of the mirror. I've tried a dozen things up that hole and nothing seems to do the trick. Of course, I don't know what the trick is. FSM is no help.
Anybody know the key to getting it off?
Old Mar 16, 2007 | 08:22 PM
bofa's Avatar
bofa
It's bonded to the windshield.. I can't really think of anything besides using the same method you would for removing an emblem.
Edit: I reread and it sounds like you do not want to remove the mount. Are you talking about the arm that connects to the mirror?
Old Mar 17, 2007 | 06:14 AM
DavesZ#3's Avatar
DavesZ#3
Correct - I want to separate the base from the mount. I dicked around with it for 30 minutes yesterday and still haven't figured out the trick. I've got a couple buddies at one of the dealerships, I guess I'll take it over there and see if they can get one of the techs to show me the trick.
Old Mar 17, 2007 | 04:46 PM
OP Z's Avatar
OP Z
H
REMOVAL
1. Remove inside mirror finisher.
2. Remove screw of the mirror base.
3. Slide the mirror base upward to remove.
4. Disconnect the connector.
Old Mar 17, 2007 | 05:03 PM
DavesZ#3's Avatar
DavesZ#3
Originally Posted by OP Z
H
REMOVAL
Good guess but that's for the homelink mirror (see my original post). The Base model Z doesn't have the homelink mirror, it has the generic Nissan mirror. There's some type of spring mechanism inside the base than keeps it locked to the mount, much like the set screw on the homelink base. There's a hole at the bottom of the base where it meets the mount. You have to stick something like a small screwdriver into that hole which I have done, but I can't figure out what to trip, bend, pop or nudge to get the damn thing loose.
Old Mar 17, 2007 | 05:19 PM
702Fairlady's Avatar
702Fairlady
The mirror in my 04 just slides up and off. Damn thing jiggles loose with my stereo.
Old Mar 17, 2007 | 05:42 PM
DavesZ#3's Avatar
DavesZ#3
Do you have a Base model or one with the Homelink mirror?
Old Mar 18, 2007 | 06:35 AM
sjavera's Avatar
sjavera
I took my base mirror off to replace with the Homelink. I used a very small flathead screwdriver and pushed from the bottom. There is a small catch that you can hear when you press the right spot. Then with the other hand, pull the mirror up. I was also scared of damaging the windshield or mount but it popped right off. (just the mirror)
Good luck.
Old Mar 18, 2007 | 03:48 PM
702Fairlady
Base with no homelink
Old Mar 18, 2007 | 06:18 PM
DavesZ#3's Avatar
DavesZ#3
Good luck.
Are you catching it while pushing the screwdriver in or do you stick it in and pry against something to make it pop loose?
Thanks
Old Apr 12, 2007 | 06:41 PM
ARMSTRONGARMS's Avatar
ARMSTRONGARMS
did you ever figure this out? i would like to know also.
Old Apr 12, 2007 | 06:50 PM
DavesZ#3's Avatar
DavesZ#3
No, I'm waiting until I get my Homelink mirror back. I don't want to break anything and be stuck without a mirror.
Old Apr 12, 2007 | 11:04 PM
ARMSTRONGARMS
if you have it figured out before me please pm me w/your findings
Old Nov 16, 2008 | 09:31 AM
ARMSTRONGARMS
bump ???????????????????????????????? anyone
Old Nov 16, 2008 | 10:16 AM
ARMSTRONGARMS
someone has had to have figured this out? i got to get my mirror off, i know it says a 4mm flat blade but some tips/or something? i dont want to break nothing
Old Nov 16, 2008 | 06:23 PM
DavesZ#3's Avatar
DavesZ#3
Yes, I finally got it off by sticking a nail into the hole. There is a metal tab/spring that keeps it on the mount of the window. If you stick a nail up there, it lifts the tab enough to get started over the mount.
Old Nov 16, 2008 | 09:07 PM
ARMSTRONGARMS
dave do you have a pic or can you get a pic of the backside of the spring thing? so i can get a idea of wtf im trying to push/press/pull/etc. size of nail etc. any more help? im afraid im going to break my glass or mount off. i want to put my homelink on any help you (or anyone)may be able to provide would be great. thanks in advance.
Old Nov 17, 2008 | 02:55 AM
DavesZ#3's Avatar
DavesZ#3
Yes, I still have the base mirror. I'll get a pic of it tonight and post it here.
Old Nov 17, 2008 | 10:58 AM
bluezup's Avatar
bluezup
get a very small flathead and push into the hole. at the same time with the other hand grab the mirror base and wiggle and push up.
all your doing with the screw driver is pushing into the hold. theres a clip inside that holds onto the mount on your windshield, just push it in.
Old Nov 17, 2008 | 03:26 PM
ARMSTRONGARMS
geeezus that's what ive been doing? Dave im hoping once i see the pics it will click. thanks for the help so far guys.
