Holding Recirculate button
Old Mar 21, 2007 | 06:34 AM
DVFlyer's Avatar
DVFlyer
Speed of White
Default Holding Recirculate button
Hi all,
After learning that the A/C comes on automatically when pushing the recirculate button, I thought holding it down might produce a different result.... it did, but I don't know what it was.
When I held the recirculate button, both the fresh and recirculate lights starting flashing. Anyone know what this signifies? I'd love to find a work around for the A/C coming on...... of course, then I'd probably complain that the windows fog up.
Mike
Old Mar 21, 2007 | 06:37 AM
kwiker's Avatar
kwiker
Shift_Dorifto
I'm kinda interested in this too...but I'm bored so i will search around and see if i can dig anything up. I will return with answers if i find them.
Old Mar 21, 2007 | 06:46 AM
DVFlyer's Avatar
DVFlyer
Speed of White
Thanks, Kwiker.
I searched here in a number of different ways but using terms like: holding recirculate button, result in too broad of a result since it finds every thing with "any" of those words. Maybe I need a search lesson.
Old Mar 21, 2007 | 06:58 AM
kwiker's Avatar
kwiker
Shift_Dorifto
Oh, well i usually try a few different things here but if i can't find it....which i haven't yet...i go to Google and try my luck there.
I might break down here in a sec and call the service department.
Old Mar 21, 2007 | 07:28 AM
kwiker's Avatar
kwiker
Shift_Dorifto
I can't find anything.
Old Mar 21, 2007 | 07:30 AM
NickRaine78's Avatar
NickRaine78
sub-ing to see the answer!
Old Mar 21, 2007 | 10:21 AM
Track's Avatar
Track
If you hold it down until both lights flash, the a/c alternates between recirc and outside air.
Old Mar 21, 2007 | 11:01 AM
DVFlyer's Avatar
DVFlyer
Speed of White
That is WAY too easy of an answer... it must be something cooler than that like adding 15hp or allowing me to float above traffic....
Old Mar 21, 2007 | 11:13 AM
SpoilsofWar's Avatar
SpoilsofWar
out of curiosity, how long did you have to hold it? I held mine this morning for like 15 seconds and it did nothing...
Old Mar 21, 2007 | 11:20 AM
DVFlyer's Avatar
DVFlyer
Speed of White
I can't remember, but it wasn't too long.... less than 15 seconds for sure. It might depend on what was selected to begin with. i.e. maybe it only works with Auto off. Or with recirc activated first etc. I can try it again when I get home.
Old Mar 21, 2007 | 11:23 AM
SpoilsofWar
Mine is an 03, so it might not even have this feature.
Old Mar 21, 2007 | 11:30 AM
Track's Avatar
Track
If you have climate control then you have this feature.
You must have your a/c turned on (the compressor) and then just hold down the recirc button for about 5 seconds and both lights will flash. After that, the a/c will automatically cycle between outside air and cabin air.
Old Mar 21, 2007 | 11:32 AM
SpoilsofWar
lol, I just realized my AC wasnt on when I tried it. Silly me
Old Mar 21, 2007 | 11:45 AM
Motormouth's Avatar
Motormouth
why would you want to alternate? any good reason?
Old Mar 21, 2007 | 12:10 PM
kwiker's Avatar
kwiker
Shift_Dorifto
To get some fresh air every once in a while....if the air you are traveling through is fresh. I went through some pretty rank air last weekend during a drive with some S2000 guys.
Old Mar 21, 2007 | 12:58 PM
StreetOC192's Avatar
StreetOC192
Interesting, so it will intermittently let in fresh air, but give you the efficiency of cooling the air on recirculate?
who would have guessed?
Old Mar 21, 2007 | 06:34 PM
mthreat's Avatar
mthreat
From: http://www.courtesyparts.com/nissan-...issan-350Z.pdf
pages 4-4 and 4-5:
Air recirculation/Fresh air
Each time the air intake button is pushed, the indicator light on the button will alternate (Air recirculation) and (Fresh air).
When the indicator light is on, the interior air is recirculated. (When the air recirculation mode is selected with the A/C indicator off while the fan control dial is in the AUTO position, the air conditioner will turn on.)
When the indicator light is on, the outside air is drawn into the passenger compartment. I - When the air intake button is pushed for longer than 1.5 seconds, both indicator lights (x and y) will flash twice, and then the intake air will be controlled automatically. During this AUTO mode, the indicator light of the currently selected mode illuminates.
I - When the air flow control dial is in the or position, the air recirculation
mode does not activate.
It has little icons in the text that I couldn't paste, so follow the PDF link to read it yourself.
Old Mar 21, 2007 | 07:29 PM
Track's Avatar
Track
That is exactly what it does. It will use recirc. on really hot days until the car is cooled a bit, then it will switch to outside air and, if needed, will switch back to recirc if it is required.
I really dig that feature on road trips.
Old Mar 21, 2007 | 07:52 PM
DVFlyer's Avatar
DVFlyer
Speed of White
Thanks for the research work!
I still wish you could select recirculate without having the a/c turn on. I wonder which wire I need to clip...
Old Mar 22, 2007 | 03:26 AM
Track's Avatar
Track
The reason the a/c compressor engages when you select recirc is to dry out the air. If not, your respiration would build up and it would become stagnant in your car and the moisture from your breath would build. The a/c removes the moisture while adding a small amount of outside air to keep the oxygen levels up so that you don't get sleepy on long trips and your windows don't fog up.
