Harness Bar interest
Old Jun 19, 2007 | 09:05 AM
  #221
CarlosCh's Avatar
CarlosCh
Originally Posted by THE TECH
It's more cause there's not really a good, safe way to mount a 5 or 6pt harness to the stock seat.
Hmmm... I see... I might be hard-headed but I will probably keep the stockers and get 4 pointers (maybe 6 pointers and see if I can custom-install them somehow).
I hope your harness bar is coming along well... I will wait for it before making any moves!
Thanks!
C.
Old Jun 19, 2007 | 09:50 AM
  #222
Stack's Avatar
Stack
Thanks!
C.
Here's the problem with doing that: No protection against submarining and/or riding-up of the lap belt into your abdomen/stomach and causing serious injury.
How many airbags does a 350Z have? For my money, ESPECIALLY for a n00b, but it applies to everyone... you WILL be safer in the stock belts, with the passive systems active, than you will with 4-point belts. This is exponentially true with a harness system without any type of Anti-submarining mechanism like Schroth's ASM cartridge.
No one NEEDS harnesses on track until they are at the advanced level and are ready to move up to stickier tires and/or to start competing.
You might do well with a harness for Autocross maybe, and if that's all your doing, then have-at-it. You might roll, but chances are you won't hit anything of any substantial substance.
Having said all that... if you insist on stock seats with harnesses, buy a 6-point system, and run the anti-sub straps from behind the seat, through the joint between the lower cushion and the seatback so you would sit on them, and they'd come up thru your legs. While this is still a compromise, it is the much lesser of many evils, and the only way some clubs will allow harnesses while using stock seats.
Old Jun 19, 2007 | 09:53 AM
  #223
THE TECH's Avatar
THE TECH
Exactly the point I try to convey when people say, "Oh the 4pt will be fine". No need to compromise your life.
Old Jun 19, 2007 | 01:21 PM
  #224
CarlosCh's Avatar
CarlosCh
Thanks for the detailed response, StacK, this is enlightening in many ways.
I will keep The Tech's and your advice in mind for whatever I decide to do in the coming weeks.
Best Regards,
Carlos Ch.
Old Jun 19, 2007 | 02:00 PM
  #225
azula's Avatar
azula
I have the sparco harness bar and I must say that it is nothing special, this would be a great deal if it went through. I had no other option when I got my bar installed and it was an *** raping to say the least...lol. Good luck guys.
Old Jun 25, 2007 | 11:06 AM
  #226
THE TECH's Avatar
THE TECH
Just wanted to update. I've had a small design change that should make the production of the bar easier. This should mean that I can schedule production with my fabricator very soon. Time frame to completion will still be ~6 weeks from that date.
Old Jun 25, 2007 | 11:59 AM
  #227
NA&CH's Avatar
NA&CH
Sounds good. Can't wait...
Chris
Old Jun 28, 2007 | 07:25 PM
  #228
skydvr350zpop's Avatar
skydvr350zpop
Keep me in mind...I am up for it.
Old Jun 28, 2007 | 08:45 PM
  #229
synth19's Avatar
synth19
Did we get any prices yet?????
Old Jun 29, 2007 | 06:49 AM
  #230
THE TECH's Avatar
THE TECH
No, we didn't.
Old Jun 29, 2007 | 07:06 AM
  #231
synth19's Avatar
synth19
If you need initial deposits/group buy price to get started.. I would be IN... pending prices are reasonable.
Old Jul 1, 2007 | 08:35 PM
  #232
zracin's Avatar
zracin
Add me to the list. (ill take mine in redline)
Old Jul 6, 2007 | 08:35 AM
  #233
pimpin714style's Avatar
pimpin714style
subscribing
Old Jul 14, 2007 | 09:50 PM
  #234
timmays350's Avatar
timmays350
any new info????
Old Jul 15, 2007 | 06:32 AM
  #235
synth19's Avatar
synth19
Originally Posted by timmays350
any new info????
Old Jul 19, 2007 | 09:11 PM
  #236
misterniceguy's Avatar
misterniceguy
+1
+2 I got some harnesses waiting on these.
Old Jul 25, 2007 | 08:29 PM
  #237
skydvr350zpop
+3 me 2!!!!
Old Jul 29, 2007 | 12:20 PM
  #238
misterniceguy
I guess this is a nogo. Guess I'm getting a rollbar instead.
Old Jul 30, 2007 | 10:36 AM
  #239
350ZV3's Avatar
350ZV3
What type of steel will be used? (i.e 120-wall). What type of welding will be used upon assembly? (i.e. MIG welded)
(Im very intersted if high qaulity and ever available)
Old Jul 30, 2007 | 10:59 AM
  #240
z-u-later's Avatar
z-u-later
I suggest you intall a 6-point harness instead of 4 or 5-point. I have 6-point harnesses and was able to install the submarine belts using the rear rail mounting points. Also, I have the rare Avalon Racing harness bar, which has a mounting point for the OEM seatbelts. I'm able to use the OEM seatbelts on the street & my harnesses on the track.
