Installing Veilside V1 sides
Old Apr 24, 2007 | 04:06 PM
BlackSpec02's Avatar
BlackSpec02
Default Installing Veilside V1 sides
So I bought some veilside sides recently and would like to install them. I tried to do it the other day only to discover that the bolts for my side skirts that need to go through the new v1 sides and also through the side skirts were took short to do this. Is there a good place to buy longer side skirt bolts or has anyone else run into this problem? Any info would be appreciated. Thanks.
Old Apr 24, 2007 | 04:15 PM
JDMZ33's Avatar
JDMZ33
Vendor - Former Vendor
Yea, I did. Got some at home depo. Forgot what size tho
Old Apr 25, 2007 | 12:14 AM
IzYou's Avatar
IzYou
Bring the screw to home depot if you lazy you can ask the salesperson if he or she can help you find the correct thread if not just find a nut that will screw unto the stock screws.
On the rears I used only 1 stock screw inner (middle of the three holes) on each side and used home depot screws on the outers. The stock can be used I think, but I wasn't comfortable using them with only a couple of turns so I bought the other screws. If you can find the screws I still have some left over PM me I'll send it over. For the fronts I think I used the stock ones I don't really remmember.
Did you get genuine veilsides? I had to keep replacing mine until I had a set which I was content with. All of them were Genuine Veilside: 1st set I got was CF outside blank inside and was too thick. 2nd set I got was way thinner and better quality, but still had flaws. 3rd set was the one with the quality I was content with.
Old Apr 25, 2007 | 07:33 AM
THE TECH's Avatar
THE TECH
+100 on Home Depot
Old Apr 25, 2007 | 11:18 AM
BlackSpec02
Sounds like a trip to the 'depot is in order.
I have a genuine lip, but bought these replica sides because they came painted my color. They look to be good quality, they weigh a little more than I expected, but they should work.
Old Apr 25, 2007 | 01:44 PM
VeilSideBrian's Avatar
VeilSideBrian
Just out of curiosity, do these pre painted parts match perfect for you?
I would imagine they would be hit and miss.
Old Apr 25, 2007 | 01:49 PM
ldawg32's Avatar
ldawg32
yeah i had the same problem with mine. they are authentic and didnt line up i ahad to give in and took it to a body shop to install. they were already painted and i treid to save money but gave in and got it done right.
it seems they put there own screws through them attached to my my car. holes dont line up for sh*t
Old Apr 25, 2007 | 01:59 PM
BlackSpec02
These are azulas old v1 sides so he had them painted and intstalled and then removed them.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Dymsi
Sep 29, 2015 11:32 AM
Suffolk350z
Sep 13, 2015 02:43 PM
