Help/Advise/Ideas Needed as well as a caution
Old Apr 27, 2007 | 04:00 AM
Jerseyplanner's Avatar
Jerseyplanner
Default Help/Advise/Ideas Needed as well as a caution
I have a '05 Touring and it is looking great. Yesterday I opened my door and discovered a tear in the grainy door panel. It just tore my heart out. After I settled down I tried to understand how this could have happened. Apparently the last time I drove it I got out of the car and closed the door with the seat belt not completely retracted. The metal part of the selt belt must have got caught between the post and the door panel causing the tear. The tear is about 1.5" long and 0.5" wide.
I don't have funds to replace the entire inside door panel so I was thinking about buying a side Z badge (don't know the official name) and just adhering it over the tear. Sound like a plan? Anyone have any other ideas? Thanks for your help.
PS Be careful when closing your door.
Old Apr 27, 2007 | 04:32 AM
tropicalypso's Avatar
tropicalypso
You can get a badge/decal to hold you over, but I recommend saving your pennies and and scouring the my350z marketplace... people sell used door panels all the time
Old Apr 27, 2007 | 04:53 AM
350Zenophile's Avatar
350Zenophile
You might get a better response if you change the title of your thread to something more meaningful:
https://my350z.com/forum/feedback-and-suggestions-for-our-forum/265698-good-idea-or-bad-idea-to-solve-problems-with-misleading-threads.html
Old Apr 27, 2007 | 06:10 AM
THE TECH's Avatar
THE TECH
Actually door panels are hard to come by on the forum from what I recall. They also cost an arm and a leg from the dealer (~350 each IIRC). Best bet may be to scour the junkyards and hope you get lucky.
Old Apr 27, 2007 | 07:49 AM
noodleman's Avatar
noodleman
one more reason to never let anyone slam your door. hope everything works out for your replacement. maybe CF door panels? :P
Old Apr 27, 2007 | 07:54 AM
Sean's Avatar
Sean
If only you had removed your seat belts to save weight you wouldn't have had this happen.
sherm
Apr 11, 2020 05:21 PM
