Headlight Condensation?
I tried searching because i thought this might have been a big issue but i couldnt find anything.
Both of my headlights get bad condensation in them. I replaced one of them with a used one from a junk yard and it has the same issue. Is there anything i can do to stop it? Drill a hole in them? remove the plastic cover and dry them out?
Also, is there a place or way i can paint the inside of them black?
Don't worry about searching on this site as its easier to repost and wait for the know-it-alls to post the link to some obscure thread with an unsearchable title.
Make sure that it isn't oxidation on the outside of the headlight. I used the
finest steel wool I could find and some Nu Finish Polish and they look pretty good.
Originally Posted by JETPILOT
Their is a Nissan recall on the headlights. You should have just brought it to the dealership and had it covered under warranty, assuming it'sstill under warranty.
JET
JET
I had mine replaced by the dealer under the factory warranty. But @ 60,000mi your not covered under the facotry warranty. I was wrong to say it was a recall. The technical term is a TSB (technical service bulletin).
JET
JET
mines a 2004, made 01/04 production date with 21k miles.
I have an appointment at the dealer to have it service on Monday. Do you think they will fix these problems?
some known issues:
-passenger window motor doesnt work properly, sometimes doesnt work at all
-Trunk shocks dont hold up, i found out the hard way
-Headlight condensation
-Right headlight shorted out
-Transmission grinds in 5th gear
-front left wheel shaking....its the hub/berring
Also, any ideas on how long it takes for them to repair things like this? I cant imagine being without my z for long...and i need it to get to work.
ur helps appreciated
some known issues:
some known issues:
some known issues:
JET
Warranty begins date of purchase. The car is covered bumper to bumper for 3yrs/36,000mi whichever occurs first. Then after that you are covered for 5 years 50,000mi on powertrain (engine/trans).
JET
JET
As i am the second owner, how would i find out when it was purchased? Run the vin?
Originally Posted by Seel
I'm getting a little bit of this fogging too. Where can I find the TSB's??? Hate the fogging...
www.nissanhelp.com/Bulletins/350Z/2004/3.htm
bcoffee20
Nov 19, 2015 06:39 PM
