How do i Clean off that Gooey stuff?
Old Apr 22, 2003 | 03:15 PM
topeewala's Avatar
topeewala
Default How do i Clean off that Gooey stuff?
anybody in here shave the "350z" off in the back?...or any emblem at all ....
..if i take it off...how will i completely get rid of that gooey stuff without damaging the paint?
any special tools or washing materials?
i can basically take it off with my hands but im just concerened about making that portion of the paint look flush with the rest of the car.
Old Apr 22, 2003 | 03:22 PM
DMONTE's Avatar
DMONTE
Pick up some citrus solvent remover that's what I used and it work beautifully. It's the real concentrated citrus remover squirt a little on a towel and just rub it in it will come right off then use a wet towel to clean off the solvent, you just don't want to leave that citrus on for two long.
D. Monte
Old Apr 22, 2003 | 03:34 PM
topeewala's Avatar
topeewala
oh niiiice. thanks.
citrus solvent remover......wtf...sounds all high tech....but its really only like....orange juice.
is there any special brand. u know i gota be overly carefull about these things.....since urs worked great....i gota ask the brand.
and did u just remove it with like..ur hand.?
thanks
`omer
Old Apr 22, 2003 | 03:43 PM
DMONTE's Avatar
DMONTE
It's called De- solv- it put out by citrus solutions, I don't remember where where I purchased it
but there's also goof off which is actually half citrus and half something else but it doesn't work as good as the all citrus one .
Old Apr 22, 2003 | 06:02 PM
alienx's Avatar
alienx
Don't know if it should be used on paint (or would work), but I've used baby oil to get sticker residue off the windows.
Old Apr 22, 2003 | 07:40 PM
rodH's Avatar
rodH
WD40 works AWESOME
Old Apr 23, 2003 | 01:03 AM
joust75's Avatar
joust75
I removed the 350z too. I used simple green then hit the area with wax and my rotary buffer. Presto! rollin stealth!
Old Apr 23, 2003 | 11:21 AM
350zSpeedRacer's Avatar
350zSpeedRacer
Originally posted by rodH
WD40 works AWESOME
That's what I've always used!
Old Apr 23, 2003 | 12:25 PM
bobbyz's Avatar
bobbyz
NO GOOF OFF.
Goof Off will strip the paint. VQ Racer is right when he says Goo Gone. It is citrus based. Or like others have said, WD40 works great too.
Old Apr 23, 2003 | 01:00 PM
zeroday's Avatar
zeroday
Originally posted by bobbyz
NO GOOF OFF.
I've used goof off on my other cars and i've never stripped off any paint. It seems almost identical to wd-40.
Old Apr 24, 2003 | 04:29 AM
bobbyz's Avatar
bobbyz
Are you sure it was goof off (yellow can). When we traded in my moms 5 series, the rims were in rough shape from the brake dust and winters. I tried everything and nothing worked to get them clean. So, I broke out the goof off and it melted the clearcoat on the rim. The dealer didn't see the damage on trade in though and all is good.
Old Apr 24, 2003 | 06:25 AM
zeroday's Avatar
zeroday
yeah it was goof off. some rims are coated in a plastic polymer which may be what was stripped off of your rim?? I know goof off wil desolve plastic if you leave it on long enough. its probably a good idea to test whatever you use on a small inconspicuous area first.
kyin
Oct 15, 2015 05:54 AM
Stevo Z
Oct 3, 2015 09:14 PM
nanotech
Oct 2, 2015 05:02 AM
Sleeper_Z
Sep 30, 2015 10:25 AM
