New toys!!! Sard/Stack RD-1 Cluster
Old Jun 6, 2007 | 10:59 PM
Justin@WestCovinaNissan's Avatar
Default New toys!!! Sard/Stack RD-1 Cluster
This one isn't quite going into a 350z, but would work on one.
Just thought I'd share our newest toy for our project car...
Don't worry, for anyone who is interested we have these available for sale. You just can't go wrong with Stack & SARD combined technology. We were all stoked when we saw it in person.
MSRP $1536.00
Just some basic info on this unit:
Simple layout and combined body - Unit allows you to make the best use of limited dashboard space by displaying various input digital.
Combine Stack ST200 analogue tachometer as standard equipment - RD-1 display features high precision and reliable analogue tachometer STACK ST200. Dial face color and scale is selectable.
Multiple channel display - RD-1 displays various information to convey the clear picture of the vehicle conditions
Selectable display pattern - Variation of display pattern is selectable. Correspond to sport and street driving condition.
1. Normal Mode - The unit assumes street driving and mainly displays speed, water temp., fuel level, and travel
distance.
2. Racing Mode - the unit assumes sport driving and mainly displays speed, water temp., oil temp., oil pres., and lap-
time.
3. Setting mode - The unit assumes engine or computer setting and mainly displays RPM, boost pres., injector duty,
and fuel pres,. Also, able to make effective use of the unit by entering air-fuel ratio and throttle divergence in to
universal input channel (VOLT-1 and 2). * Air-fuel ratio meter is not included.
Function to analyze driving data - Data analyzing functions can be used after circuit or test driving.
1. Peak-hold - Displays memorized peak value.
2. Data display - Displays loads mass-storage maximum of 30 minutes data recording. Replay speed can be adjusted
such as slow-motion and fast-forward.
3. Lap-time - Times laps manually during circuit driving. External stop watch switch is connectable to input
4. Lap chart - Memorizes and displays up to 99 laps on the chart screen.
Easy search jog dial - Jog dial simplifies the operation of display search and function setting.
Indicator lamp - RD-1 display is supplied with indicator lamp as standard. This allows you to replace dashboard instruments without hindering functions and visibility.
1. Indicators - Engine check, turn signals, parking, high beam, fuel warning.
RD-1 Display data / Other function
RD-1 displays - Speed / RPM / Fuel level / Fuel consumption / Travel distance (odo and trip) / Boost pres. / Water
temp. / Oil templ. / Oil pres. / Fuel pres. / Injector duty / Volt-1 (universal input) / Volt-1 (universal
input) / Time / Lap-time.
RD-1 other function - Unlocking speed limiter / Shift timing light / Maintenance warning
Old Jun 6, 2007 | 11:01 PM
BJF2K's Avatar
BJF2K
tighttttt!
Old Jun 7, 2007 | 06:19 AM
PM-Performance's Avatar
PM-Performance
Nice, but for $1500+ I would want the tach to Zero out when not on.
Old Jun 7, 2007 | 06:24 AM
THE TECH's Avatar
THE TECH
Stack makes great stuff! I had their full unit on my last car.
Old Jun 7, 2007 | 06:32 AM
AlvinHuyN's Avatar
AlvinHuyN
Nismo 370Z #697
wow high rollin'
Old Jun 7, 2007 | 06:58 AM
Lawy'dU's Avatar
Lawy'dU
The bennifits of owning a G. If I wanted to install one, which I do eventually, I could do it on my car, but it wouldn't work on the Z's since your cluster is kinda funky.
Old Jun 7, 2007 | 11:23 AM
mlam002's Avatar
mlam002
balllin..striaghttt balllin
Vigman
Nov 17, 2015 04:34 AM
redlineRED350z
May 17, 2003 05:58 AM
themyst
Cleaning & Detailing
Feb 9, 2003 09:36 AM
JDZ
Sep 15, 2002 04:20 PM
