Switch out 03 headlights to 06 headlights?
Old Jun 9, 2007 | 06:05 PM
brandonhh's Avatar
brandonhh
Thumbs up Switch out 03 headlights to 06 headlights?
I just purchased an 03 350z, and want to change out the headlights with the 06/07 style headlights. Are the wiring harnesses the same? Is any any modifications required to install the new headlights? I've searched for info on this, but couldnt find any. Thanks.
Old Jun 9, 2007 | 06:08 PM
vaughn1576's Avatar
vaughn1576
Not the same. You can make it work though. Many people have.
You can find more info through search trust me...I did.
Old Jun 9, 2007 | 06:14 PM
JETPILOT's Avatar
JETPILOT
Are they 03 HID's?
JET
Old Jun 9, 2007 | 07:57 PM
brandonhh's Avatar
brandonhh
yes, they are 03 hid's. Ive searched, and I've found pictures of 03's with 06's on them, but not any info on actually installing them.
Old Jun 9, 2007 | 08:22 PM
vaughn1576's Avatar
vaughn1576
Motoring has a how to.
Old Jun 9, 2007 | 08:31 PM
brandonhh's Avatar
brandonhh
link?
Old Jun 9, 2007 | 08:37 PM
vaughn1576's Avatar
vaughn1576
This is for non-HID
Link
Your HID lights may be plug and play though. There have been many threads on the subject here.
Old Jun 9, 2007 | 08:59 PM
DJShan209's Avatar
DJShan209
vaughn1576, whered you get your 06/07 style from? And did you have to take off the front bumper by any chance?
Old Jun 11, 2007 | 01:32 PM
buffmanjeff's Avatar
buffmanjeff
this has been answered a number of times...
https://my350z.com/forum/exterior-and-interior/263109-swap-headlight-from-05-to-06-a.html
https://my350z.com/forum/showthread....headlight+swap
Old Jun 11, 2007 | 01:33 PM
buffmanjeff
yes you have to.
Old Jun 11, 2007 | 03:40 PM
JDMFairladyZ33's Avatar
JDMFairladyZ33
If you have 03-05 HIDS it's plug in play for the 06s. You will have to take your front bumper off because there are two screws on each light that are covered by the bumper cover. It's pretty easy:
1) Pop off the 6 plastic tabs on under the hood
2) Take off the 10 bolts on the bottom.
3) Turn your wheel to each side and pull the plastic piece over the wheel aside and undo the 3 bolts inside.
The cover should come off. Each light is held on by 4 bolts. Take them off and unbolt the harness. Install the 06 lights and put everything back in reverse order.
Old Jun 11, 2007 | 08:55 PM
Track's Avatar
Track
You are in a perfect position to call Dan at MrZipps. Most people are hesitant to send their headlights off and have their Z down for a little while. Call Dan and see about having him do his thing to some new '07's and send them to you already done. Then you just swap them out, and it is plug-n-play.
Since you have an '03, the turn signals will remain lit, but they will blink whenever you signal a turn. If you cut the blue wire leading to the unit, the light will remain OFF, but still blink when you signal a turn.
This is also a great chance to upgrade to 6000k units.
Dan did the following to mine:
1. Cleared the light diffusers/reflectors
2. Painted Housing (custom Porsche color)
3. Swap parking lights for LED's to better match HID headlights
4. Swap OEM projectors to 6000k units
Then I added the AUT eyelids and swapped the turn signal bulbs out for "Stealth Bulbs" from Intense. Since I cut the blue wire going to the unit, I can put whatever bulb I wish into that socket, and it will light only when I signal a turn:
Old Jun 11, 2007 | 10:39 PM
wtf no turbo's Avatar
wtf no turbo
I have 05 with hid and mine plugged right up
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
JGee450
Sep 30, 2015 04:32 AM
