How to install HID bulbs
hey guys, i just bought a set of replacement bulbs for my Z. I was gonna install it, but I cant see how I would be able to get to the factory bulb.
Do I need to remove the headlight from the car in order to get access to the bulbs?
Thanks
Thanks
Thanks
Thanks
The way you are supposed to do it is remove the wheels and pull back the inner wheel well plastic.
Once you do that, you will have access to changing the bulbs on the headlamp. The reason why I say this is the best way is because once you remove your headlights, you might have to adjust it when putting them back in.
Damn, never had to do so much just to change bulbs, but f*** it, it's worth it!!
N00b question - i was told the D2R & the D2C bulbs were essentially the same thing, any truth to this?
